04-14-2019, 09:44 PM | #2 |
Congrats on the new Hawk.
04-14-2019, 10:22 PM | #3 |
Woohoo!
04-14-2019, 10:39 PM | #4 |
Now the fun really starts! Keep us posted on your adventures and mods to your new Hawk!
Enjoy the Ride!
Dan-O -2018 Tao Tao HellCat - DOA -2016 Hawk 250 - Kitty Hawk - eBay exhaust, Mikuni carb(120 main/30 Pilot), airbox mod with K&N filter, digital cluster, total LEDs, 17/45 sprockets, RK chain, Shinko 244 tires, trunk, aftermarket levers, burrito tube, skid plate, Sargent Cycle Seat... -2003 HD Sportster 100th Anniversary -1999 Buell X-1 Lightning - Race kit, Buell Seat |
04-17-2019, 08:53 PM | #5 |
Welcome to the sickness.
05-18-2019, 10:42 PM | #6 |
Love my hawk but does require a little more attention than say a Honda or yamerhammer but a good bike all the same. I have did run into a prob with Oring chain maybe someone can answer. I went with the 17/45 sprocket setup and it will hit 70 but I can’t get the oring chain on because it hits the engine case. With 17 front sprocket the oem chain runs real close. I may have to go with the 15/40 setup but for now just gonna ride. Any suggestions
05-18-2019, 11:19 PM | #7 | |
My current Hawk has a 13 tooth with a 520 chain, which is similar in size to the 428 chain and 17 tooth, maybe a teeny tiny bit smaller, and it doesn't have an issue at all. If you aren't up for grinding away at the inside of the sprocket cover where it touches the chain, the alternative ratios would be a 16 front 43 rear or the 15 front 40 rear you mentioned. Going with the 16 front would leave you some wiggle room for gearing it up a little more later on (like a 39 rear) if you decide to do so.
