10-24-2010, 02:52 PM | #1 |
Pitster 400 and the Lack-o-Trip meter
So, what do ya'all think? To me it looks like the instrument cluster from a pitster 250 is a shoe in for the existing cluster. I cannot live without a trip meter and I don't want to have any extra 'stuff' hanging in my view. Ideas?
Daddy 8) |
10-24-2010, 02:56 PM | #2 |
according to pitster it is standard.
Digital Speedo W/ Trip Odometer: standard
10-24-2010, 04:37 PM | #3 |
errr, no.
the LXT400 from Pitster does not come with a digital anything. -But I'm wondering if one would drop right in. I've asked the Pitster folks but haven't received an answer. Actually, I've asked them a bunch of time even for a recomendation and I get zip. Granted it isn't they job to satisify my curiosity, but Christmas is comming and screwing around with a petcock in traffic is not an acceptable solution to running out of fuel. Daddy 8) |
10-24-2010, 04:54 PM | #4 | |
Re: according to pitster it is standard.
Daddy, I recommend a Trail Tech Vapor computer for your LXT 400. Among other things, this unit contains a digital tachometer, speedometer, engine temperature gauge, clock, and trip odometer! Run a pickup coil wire to your left fork, and you can ditch the speedometer cable on your right fork. Spud
10-24-2010, 05:45 PM | #5 |
good to know, i wonder what else is in error. i'm seriously considering one of these. are the wheel sizes correct?
WHEELS AND TIRES Front Wheel: 1.60 x 21" Rear Wheel: 2.15 x 18" |
10-24-2010, 11:03 PM | #6 |
BAH! Spud, as usual you are correct. I even have that post bookmarked. My mind is gone and I'm headed out of town (again). Gar!
daddy 8) |
10-24-2010, 11:46 PM | #7 |
i 2nd the trail tech device, check out the videos on youtube of it.. trailt ech also makes a temp reader that has a painless install and if you put the the time in for researching how to install a gas gauge it shouldnt be to hard to add one..
200cc beast replica,carsoli cdi,performance coil,fmf powercore 2,uni air filter,hour/tach meter,jetted mikuni carb,msr bars,moose racing grips,yz250f clutch perch,D.I.D chain |
10-24-2010, 11:56 PM | #8 |
Q, which uses a similar instrument cluster lacks a trip meter. Big PIA. Also add in that the odometer reads kilometers it's a bit more inconvienent.
I just memorize the last 3 digits and go from there. I then use the speedometer face plate to convert kilometers to miles.
Happy to serve. |
10-25-2010, 01:02 AM | #9 | |
10-25-2010, 10:43 AM | #10 | |
Need a little help here since no trip meter on my XF200
Are you kidding? Memorize the last three digits? I can't even even remember my phone number or why I went out to the shop to get something. Anyway, someone help me find one of those little plastic gizmos that had digits that you could set to act as a trip meter. I looked all over the net but no luck. I can see me running out of gas on reserve. |
10-25-2010, 12:48 PM | #11 |
Happy to serve. |
10-25-2010, 01:04 PM | #12 |
ebay.com
10-25-2010, 02:24 PM | #13 | |
Re: Pitster 400 and the Lack-o-Trip meter
The bike I rode did have the wheel and tire sizes listed in the Pitster Pro specifications. I might be wrong, but I believe the shock absorber on the LXT 400 I rode had adjustable spring preload, but no adjustable rebound. As stated previously, the bike doesn't have a digital speedometer with trip meter; it has the same, analog speedometer as the QLink XF200/XP200. Spud
10-25-2010, 02:53 PM | #14 | |
That will work. Thanks |
