06-12-2016, 01:03 PM | #1 |
Side boxes latch bolts loose
I found all of my side box latch bolts loose even though there was a lock washer.
06-12-2016, 01:32 PM | #2 |
Same here, noticed that around 500 miles. Also my rear left side luggage case - the rear bolt is not loose..but there's some wiggle room of the case plastic against the bolts mounting nut.
'16 Red RX3, K270's, 13t Front, Fog lights, Tusk Bar Risers (4K mi.) '82 Suzuki SP250 (11k Miles) '85 Honda Rebel 250 (Sold April 2016) |
10-31-2016, 10:46 AM | #3 |
Found that with my left case as well. Wiggles but the bolts are as tight as they get.
Will pull the bag off this weekend and see what's what
2008 Honda VFR 2009 Kaw Concours 1998 Vmax couple of 73 Yamaha RT 360's |
10-31-2016, 09:29 PM | #4 |
Nylock nuts and thread locker together.
11-01-2016, 08:29 AM | #5 |
Thats the problem....the bolts aren't loose, only the bag is. The bolts must have a shank on them and run out of thread? No nuts on the back side...
11-01-2016, 09:15 AM | #6 |
Put some rubber washer on there.
11-01-2016, 09:46 PM | #7 |
Ok,I see what you mean now.Maybe time to pull every thing apart and have a look see.
