08-21-2019, 03:57 PM | #1 |
Rps Magician won't start, whats new...
So my RPS Mag has had problems out the crate, i understamd i wouldnt get perfection but come on. New spark plug, starter solenoid, 12v battery, oil change. Alot more but you get the point. the bike wont start again and i think i finally figured out why. This wire which im assuming is some kind of sensor was pinched in the front gear sprocket. Does anyone know a name or part number for this on a 2018 RPS Magician 230cc
08-21-2019, 04:09 PM | #2 |
That is the gear selector switch and shouldn't have anything to do with it running. You can either contact the dealer you bought it from to send you a new one or just pick one up here. https://www.vmcchineseparts.com/prod...0-cg250-engine
Check all the connectors up by the battery and make sure all the pins are pushed all the way in and locked in place. I had a few loose pins on mine that gave me trouble.
08-21-2019, 04:24 PM | #3 |
Thanks that explans why i dont have a 5th gear indicator light. I hope its just a lise wire or pine. I dont even have 70. Miles on this thing but i still love it For around town .
08-21-2019, 04:28 PM | #4 |
Other things to check are that the kill switch wasn't turned on by accident. (A few of us here have done that lol) , If equipped with a safety switch on the kick stand it will not start unless the kick stand is up.
08-21-2019, 04:34 PM | #5 |
the kick stand got me on my day one with the magician.
