09-24-2023, 06:34 PM | #1 |
What motorcycles have Zongshen NC250
I see the GPX fse250r has it but what other bikes in the US have that same engine? Also looking for bikes with the nc300s engine.
09-25-2023, 07:52 AM | #2 |
09-25-2023, 08:57 AM | #3 |
Trailmaster has the TM38 with the NC300 water cooled OHC engine. This is the single OHC version, with 298cc displacement, 6 speed transmission, makes about 31hp. ~$3800 from Family gocarts, for instance. Fully adjustable KKE suspension like the Temp X.
THis TM38 is at the top of my list at the moment. I might sell the Templar and get one. No lights, but there are kits to make it street legal.
09-25-2023, 01:08 PM | #4 |
Thanks I'll have to check that one out!
05-28-2024, 01:15 AM | #5 | |
05-28-2024, 07:43 AM | #6 | |
There are many options out there, but I had to design and fabricate wiring. I kept the system isolated from the bikes magneto type ignition (always on, with kill button) except that I patched the ignition swith into the kill button circuit. In the on position, the ignition powers the DRL, tail lights, horn, turn signals, and a separate handlebar switch for the headlights. I have the battery isolated from the bike, but has a battery tender lead to rechage the Lithium battery (no regulator rectifier). I got a polysport H4 type headlight assembly that has DRL and an H4 type halogen bulb, but I replaced the bulb with an led hi/lo element for lower power consumption. So I will charge the battery in the garage via the battery tender connection. This guy went with a kit from Street OHV: There are other options out there.
-2022 5 speed Templar X Orange, OEM 51T rear sprocket, 14T front sprocket -NOS 2020 KTM 250SX (2-stroke motocross), less than 10 hours on it Last edited by Thumper; 05-28-2024 at 08:42 AM. |
05-28-2024, 10:42 AM | #8 |
You took the words right out my mouth. I've been eying the TM38EX for a while.
05-28-2024, 11:19 AM | #9 |
BBQkid just needs a lighting conversion plan.
He is asking about his EGL NC300 A17 (in post #5). I just put that TM38 video up since the lighting conversion would basically work the same way. There are partial/full kits. Street OHV has a complete options build thing on their website. I used a 1PZ kit.
05-28-2024, 12:01 PM | #10 | |
05-28-2024, 05:41 PM | #11 | |
