Old 05-08-2014, 03:06 PM   #1
visching101   visching101 is offline
V Thunder stalling when i give it throttle
Ok so i just got my hands on an 06 V thunder. I have had it for 2 days and have slowly been making progress with the issue. When I got it, it would start but sounded like is was revving up a little and then would fall back down at idle. Last night I got it to a steady idle. But after i let it sit and warm up, when i go to get on the throttle, it just cuts out and stalls.
Any help would be great.. Thanks.
Old 05-09-2014, 12:15 AM   #2
Welcome!
Have you cleaned the carb? I bet the jets are partially clogged.
Old 05-09-2014, 02:10 AM   #3
Krasi_BG   Krasi_BG is offline
And make sure you have a clean air filter before fiddling with carb settings (after you clean it!).
Old 05-25-2014, 04:44 PM   #4
pchitti   pchitti is offline
pchitti's Avatar
Does it have an accelorator pump on the carb? It might not be accuating it if it does.
