Old 05-21-2015, 05:13 PM   #1
jimjr21   jimjr21 is offline
Performance parts
Just got my prototype valves in.
Next up flow bench testing, then dyno.
More goodies on the way.
Currently In the garage in various states of running (or not) order
2015 Rx-3 super speedy blue
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
1952 Ariel Square four
Old 05-22-2015, 12:34 AM   #2
What are the valves made of?
Old 05-22-2015, 10:13 AM   #3
Forged stainless steel
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
Old 05-22-2015, 11:02 AM   #4
Are you planning anything over the top, like a five angle cut?
Old 05-22-2015, 11:25 AM   #5
1,3, 5, radius are all the same effort. Just change the cutter.
I have a Sunnen VGS-20 in the shop. Makes this operation so easy.
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
Old 05-22-2015, 11:47 AM   #6
Very nice, Jim.
Old 05-22-2015, 01:06 PM   #7
I would love to have access to a wonderful toy like that!
Old 05-22-2015, 03:54 PM   #8
Co2   Co2 is offline
Nice project but..?
1 year ago , read my moto " owner manual " said after 1000 km check and adjust valves , totaly my fault.
Good but " owner manual " not added valves clearences , later i search surf on internet universe
Documental a video (or a user said, i forget,) same type zs177mm said 0.15 mm exhaust , 0.10 mm intake
And i get that settings , cam shaft signs is ok , topdead is ok , sett after performance is down , and urgent need 100 kilometer range drive wrong values total 200 kilometer but on road request high performance ı used my moto full thortle.
And happy end....... motocycle electrick start is ok non problem , but kick start isnt work... later hard start too electric to.
Checking my intake valve example, old.. (damaged up valve, down valve is my reserve/replecament valve intake it normal)
Damaged valve left side.
On pictures maybe hard seeing, but on eye and hand control disaster sharp same a razor damage. and dimension smallest corosion.
İ just remending , my fault big fault, extreme drive = but my moto material (metalurjic valve smooth) tolerated my fault and save me better or heavy damaged my motor or cyclinder head.
İ think if u used better hard steel material on our modift, moto cyclender head maybe cant tolareted any failed..
(Tarzan style lang is awesome : ) ) i hope understand me
Old 05-22-2015, 04:01 PM   #9
The valve lash for the ZS177MM/NC250 engine is as follows.
Intake Valve: 0.04 - 0.06mm
Exhaust Valve: 0.04 - 0.06mm
Old 05-22-2015, 04:02 PM   #10
Co2,
Are you saying the valve face was damaged from too much clearance?
Or some other issue?
2003 BMW F650GS
2001 H-D V-Rod
1999 Ducati 750SS
1997 Yamaha Riva
1995 KTM 250
1970 Honda CB350
Old 05-22-2015, 04:04 PM   #11
Co2   Co2 is offline
Yes , me too learned that values after damaged my valves ^^ , again thanks livingcebuforum and mr.david aisawing + crossfire moto company same ansvered me.
İ hope on this forum to , any other problems solved, and helped together
Old 05-22-2015, 04:10 PM   #12
Co2   Co2 is offline
Co2,
" Are you saying the valve face was damaged from too much clearance? "
too much clearance + our modfy new valve , maybe better hard steel , any a fault on valve sett = hard material valve heavy damage our moto cylender head damage.
Yes , i later learned that clearenced 0.04 mm , 0 .06 mm , and i posted on Turkiye forum of motosiklet.net/ my moto topc = http://www.motosiklet.net/forum/moto...m-basligi.html
And coming many posts said interesting very tight values,impossible,bla bla bla , but all forget metalurjy is on techno age, and this motor tight tolerance high compression , and this moto is " water cooled ". i think all mixed old version air cooler moto type clearences.
İ learn this, but learn price is expensive for me^^
Note ; maybe versions is different idk , my moto is zs177mm 5 gear and carburator version, maybe different EFİ zs177mm idk.
Old 05-22-2015, 05:06 PM   #13
Adjuster's Avatar
I can see the honed razor sharp edge at the top of his valves. The metal is beat so thin it is falling off.
Old 05-22-2015, 11:27 PM   #14
Originally Posted by Co2 View Post
...Note ; maybe versions is different idk , my moto is zs177mm 5 gear and carburator version, maybe different EFİ zs177mm idk.
The valve lash specifications are the same for both versions of the ZS177MM/NC250 engine, whether the engine has a carburetor, or EFI.
Old 05-22-2015, 11:29 PM   #15
Yes, that is a case of major valve recession.
