Old 10-28-2015, 04:24 PM   #1
Inroads   Inroads is offline
Top speed indicated
i saw 88 mph indicated @ 10,000 RPM's
With 1 tooth lower engine sprocket sitting upright
What are you seeing ?
Old 10-28-2015, 04:57 PM   #2
dave92029   dave92029 is offline
Doh! My rx3 Redlines @ 9,000 rpm
Have you changed the engine oil or adjusted the valves yet
Redline refers to the maximum engine speed at which an internal combustion engine or traction motor and its components are designed to operate without causing damage to the components themselves or other parts of the engine.[1] The redline of an engine depends on various factors such as stroke, mass of the components, displacement, composition of components, and balance of components.
The word is also used as a verb, meaning to ride or drive an automotive vehicle at its maximum engine speed.
10,000rpm on a RX3
Dave
Old 10-28-2015, 05:06 PM   #3
Trying to keep this simple.No GPS.
As the title states so we can compare apples to apples.
RPM not important.Indicate stock or 1 tooth lower engine sprocket.
Old 10-28-2015, 10:04 PM   #4
This brings up an interesting side point; perhaps the tach is also inaccurate. Not sure how one would go about proving or disproving that theory.
Old 10-28-2015, 10:19 PM   #5
You're missing the part about keeping this simple.
Indicated speed........period....thanks.
Theories and speculation on another thread....Just the facts here.
It's a comparison,all RX3's have the same speedo error.
Remember the 1st rule...keep it simple.
Old 10-28-2015, 10:31 PM   #6
Apologies from my bi-polar brain. Back to your indicated speed thread.
Old 10-29-2015, 01:00 PM   #7
Danimal   Danimal is offline
Banned
Sorry for the bubble burst, but depending on 18 or 19" front wheel and depending on tires run, not all RX3's have the same indicated speedo error.
Would be better to ask for actual, as most now run a GPS
Old 10-29-2015, 01:31 PM   #8
I am looking for indicated speeds.Can't be anymore clear.Read post #3,no GPS.
I want to see how my 88 mph stacks up to the rest.
And yes only 18" wheels.
Wow,enough with theory class,how bout some hard numbers...Thanks
Old 10-29-2015, 01:35 PM   #9
keithmaine   keithmaine is offline
keithmaine's Avatar
I am more concerned with every day facts like 0-60 mph and what is the real cruising speed say if one was to do highway driving.
All this would depend on rider weight, wind conditions, road conditions, gearing as already mentioned, tires, etc. just too many variables.
Top end on a 250cc motorcycle I have to ask why is this a concern?
Please do not take it the wrong way inroads just curious why you are coming so closing to blowing your engine @10,000 rpm on a 9,000 rpm redline
2016 Versys 650 LT, 2015 RX3 Red, 2011 Ural GearUp,
Old 10-29-2015, 01:45 PM   #10
I have an idea,why don't you start your own thread and ask it the way you feel is correct.
In the meantime this is my thread and this is the way I want to conduct this test.
And it is quite ok to top your bike out WFO.
I am trying to keep this simple but people won't let me.
Old 10-29-2015, 02:02 PM   #11
keithmaine's Avatar
Did not mean to offend
Old 10-29-2015, 02:09 PM   #12
Calm down, we have a nice friendly group here.
The redline for the NC250 engine must certainly be higher than 9,000 rpms. I wouldn't trust the red numbers on the tachometer. I believe the engine in the Yamaha TW200 has a redline of 10,000 rpms, and the NC250 engine is certainly designed to rev higher.
I also got an indicated top speed of 88 mph with the stock, 14T/44T sprocket combination. I didn't note the engine rpms at the time.
Old 10-29-2015, 02:50 PM   #13
Banned
What tires on those 18" wheels?
See? It really isn't as simple as you are trying to make it out to be.
So you want feedback only from 18" fronts....with the same tires as you.
And no GPS? You Sir are in the minority with that one...especially on a dual sport
Good luck with your sampling
Old 10-29-2015, 02:58 PM   #14
We do our best to maintain a friendly atmosphere on these forums. We are not here to argue with each other.
If nobody else wants to reply with the data the original poster (OP) has requested, I'll close the thread rather than let it deteriorate into a big argument.
Old 10-29-2015, 03:20 PM   #15
Banned
Sorry Spud.
Wasn't my intent to argue, just pointing out facts.
