08-12-2016, 09:53 PM | #1 |
Independence VA 8-18 to 21
Heading up from Charlotte to New River Campground near Independence VA next weekend. Another friend of mine who bought a Hawk about 6 weeks ago is going to be there too. anyone else wanna show up for the weekend?
08-12-2016, 10:13 PM | #2 |
I MIGHT be able to make it for a quick ride. I'll have to play it by ear. PM me with the details and I'll see what I can work out. I'd love to meet you all and do some riding.
08-22-2016, 03:44 PM | #3 |
We managed to have a good weekend. it was humorous that this was a COG (Concours Owners Group) rally, yet there was only one Concours in the group. Everyone was on adventure tour bikes. my Hawk was a bit tiny beside the rest, but it performed fine. It even made it on about 10 miles of I-77 in VA from exit 64 to Witheville. it managed to run 55-60 even up the grades. I tried not to run WOT as much as possible, giving the little motor a break. I had to stop and strip the carb once on the trip to clean out the main jet. no harm and only 15 minutes to do it.
08-22-2016, 06:14 PM | #4 |
impressed, carb job on the fly. nice. must have been running pretty bad to warrant that. did you buy the carb cleaner spray or have it with you for just used fuel?
the carb is easier to get to on the hawk off to the left (correction: right) side it seems from pics. the bashan , it's buried in the center between frame weldments so it's a tip of the fingers job , will pull mine one of these days. i do have the slide removal procedure down although.
08-24-2016, 09:16 AM | #5 | |
08-24-2016, 10:58 AM | #6 |
Good news! it only takes about 8 minutes to take apart and clean a carb/jets on a bike with a POD filter
I know the HAWK already "has a filter"... but this is why I tell everyone, I would still have an external K&N Fuel Filter on my bike... at least with the K&N filter, I know how many Microns it filters down to...
08-24-2016, 11:06 AM | #7 | |
08-24-2016, 04:26 PM | #8 |
az...my understanding---a pod filter is a air filter device at the intake of a carb.
don't understand what your saying. how does having a pod filter save time on removing a carb from a bike? it still has to be removed regardless if stock or pod equipped, correct? or is this one of those, if you have to ask....
08-24-2016, 07:38 PM | #9 |
Depending on the bike/design of the air box/carb/engine mounting setup... it can take FOREVER to remove the carb on a bike with the stock air box mounted to the frame/carb/engine...
On the Bashan; It was impossible to remove the carb with the stock air box design on my bike... you had to remove the seat, all the plastics (tail light/turn signals and shock plastic mud guard too), unbolt the air box and slide it back towards the rear tire several inches while making sure not to catch anything on wires/fuel lines/frame parts/etc..., finally you can unbolt and remove the carb... total time was well over 35 minutes... Remove the stupid piece of plastic with the non working air filter (the stock air box on the Bashan in this case)... slap on a "POD Filter" of your choice (UNI 43mm in this case)... New Total Time to remove, clean or re-jet the carb... is now a total of 3 to 8 minutes depending on if I drop a M6-1.0 nut into parts unknown... only tools I need, a 10mm wrench for the carb nuts, 1/4in socket and some extensions for the air filter, a 2.5 allen/hex wrench and flat head screwdriver for the carb bowl and jets.
08-24-2016, 09:17 PM | #10 |
This is good information. I did not consider the fact of physical removal has to be by the way of the airbox. Damm your right pita.
Pic of mine. I might try removal of the cylinder intake along withe the carb. Seem like there may be enough room to slip it by. If I remove this intake to the cylinder do you think it would damage it? I am getting sputtering a top end in 5th so I may need to pull and clean will still do 55 without sputtering but any faster and it will start sputtering. It has always done this since new but seems to be getting worse. Has about 5000km
