11-22-2016, 08:03 PM | #1 |
New owner Roketa db-08-250 need help!
Just got two Roketa db-08-250 (LHJ) bikes.
Brand new owner need help putting them together correctly. Assembly instructions? Engine oil? Break fluid? Mikuni VM26 with 30mm Carburetor?? Is it worth it? What size spoke wrench? What torque settings? 35lbs??? What is a good chain replacement? Valve adjustment? Any tips and/or info would be great. Thanks |
11-22-2016, 08:19 PM | #2 | |
15 - 40 weight diesel oil or wet clutch motorcycle oil. DOT 4 brake fluid. |
11-22-2016, 08:29 PM | #3 |
Thank You.
Will the existing throttle cable fit on the mikuni carberator without modifications? |
11-22-2016, 09:13 PM | #4 |
Is this the storm?
11-22-2016, 09:30 PM | #5 |
yes this is the Storm
11-23-2016, 09:43 AM | #7 |
Seems like there is a build thread of a storm on this site.
11-23-2016, 10:29 AM | #8 |
As mentioned, there's build threads here on a bunch of CG motored bikes. They all share a ton of the same basic parts, though some look fancier than others so usually any info you run across is good info.
As Merlin said, the Mikuni is preferred and I run them on everything, mostly because they're super cheap, there's a variety of available jetting that is not easy to find on the stock PZ Keihin clone. The main thing is, if it runs good at your elevation, you win! They usually come woefully lean though, to pass EPA regs. This will cause a cold blooded bike and a bad stumble at wide open throttle. Congrats on the two Storms! Those are one of the favorites around here and getting hard to find.
11-23-2016, 12:09 PM | #10 |
It would of been great if that would of came with the Hawk. I searched high and low to find one before I even got the bike. But I figured it all out.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-23-2016 at 01:07 PM. |
roketa db-08-250 storm |
