02-14-2017, 02:28 PM | #1 |
Forks on the Stallion & Brozz
I am interested in possibly upgrading the forks on our Hawks to what appear to be sturdier forks that are present on the Stallion and newer Brozz. If the fork style on the Hawk is "Inverted" (I can never keep it straight) then these are "Standard", with the smaller diameter part of the fork on the wheel side rather than the tree side. On my first run I noticed some fork flex when braking...not enough to be alarming but I didn't like it. I am thinking about a nice big fork brace where the wire keeps are mounted (might be cheaper) but thicker forks might be a good upgrade as well.
Has anyone tried this or looked into possible upgrading using parts from other Chinese bikes?
2002 BMW R1100S, 1999 Kaw Concours, 1991 Kaw Eliminator 250, 1969 Honda Trail 90 Too many damn mopeds... |
02-14-2017, 02:49 PM | #2 | |
02-14-2017, 03:02 PM | #3 |
they twist around the axis formed by the fork stem. I understand it is because you have a decent disc brake on some long forks and a fork brace will help a lot to minimize this as well as be a helpful offroad. It may be the quicker and easier way to provide support. The bit of searching I have done so far hasn't revealed much. I feel like I would have to order spares from a dealer and that could be a signficant amount, vs. some flat bar steel bent into a U and drilled to accept the mount points on the forks.
02-14-2017, 03:51 PM | #4 |
Is your Hawk new? First thing I'd do is change the fork fluid, if you haven't already. This makes a world of difference on their action.
You have "regular" forks on the Hawk, that have the thicker sliders on the wheel end. USD (Just think Up Side Down) forks have the thick tube (slider) inside the trees and the thinner tubes down at the wheel. You'd have to change your trees to run the USD forks. The regular forks with good (and proper amount of) fluid work just as well, in my experience.
02-14-2017, 05:29 PM | #5 | |
However, a good fork brace will do more than simply switching to USD, unless the USD are particularly more stout than stock. the question I have not researched is what the dimensions of the USD fork are with regard to tube diameter, exterior and interior. on a side note...anyone know of a source for fork braces? you guys are making me spend money again! |
02-14-2017, 06:01 PM | #6 | |
02-14-2017, 06:05 PM | #7 | |
Also, has anyone seen the Brozz "Iron Head Protector" model before?? I WANT THAT HEADLIGHT RACK!
02-14-2017, 10:29 PM | #8 | |
That's the main reason for USD forks, it's so the beefier, fatter part of the fork is held in the trees, which makes them far more rigid and supposedly flex far less. Some say the dampening works better but I don't ride hard enough anymore to tell the difference.
