01-22-2019, 11:01 AM | #1 |
Removing catalytic converter?
So, there are three china bikes I have my eye on. The SG250 and RX3 from CSC, and the Italijet/SSR Buccaneer. All these bikes have catalytic converters in the pipes. Will removing the cat add a little performance to these dimunitive 250s?
Charles. |
01-22-2019, 11:35 AM | #2 |
Yes it will. Your are removing a restriction in the exhaust. It will also require re-jetting of the carb.
01-22-2019, 12:16 PM | #3 |
Well, two out of the three bikes I'm looking at are fuel injected...
Charles. |
01-22-2019, 12:32 PM | #4 |
I missed that. On the fuel injected engine the ECU will relearn and compensate for it but you will probably set off an error code.
