08-12-2017, 11:17 PM | #1 |
Hawk Headlight questions and issues.
1) what is the small bulb for? Down and left from main bulb.
I thought it would be a daytime running lamp but it runs with the main bulb. 2) I'll need to black out top of headlight assembly as distracting light shines up. 3) Anyone replace the headlight assembly completely?
2017 RPS Hawk - 15/50. Rear Foot peg delete. Horn Delete. Tank Bag. Airbox mod. NGK Plug. MSR Shifter. VM26 carb Jetted 120/17.5, middle clip, 1-1/2 turns. |
08-13-2017, 01:15 AM | #2 |
1. It's supposed to be a running/accent light. Mine never worked either, and also only comes on with the headlight. I have a feeling that some of them were wired wrong. To me it's not really a big deal, but I guess it depends on your local laws as well.
2. Mine also did this. I simply put a strip of electrical tape across the top/inside portion of the headlight to block it. Probably not the best long-term solution, but it has worked up to this point. Some black nail polish might be a better permament solution. 3. I am not aware of that at this point, but I have considered it. I just dont know what I would go with, and I don't mind the headlight up to this point after doing the LED bulb.
08-13-2017, 08:45 AM | #3 | |
08-13-2017, 10:50 AM | #4 | |
The following is a fragment from my previous post regarding that light. ----------------- Useless position light has been removed and the wires cut. |
08-13-2017, 12:31 PM | #5 |
I'm going to try to rewire that light for proper behavior, especially since you can turn the lights completely off on this bike. I'd hate for the headlight to be off and have no running light. Plus I have some led side markers and that would be a good place to tap into.
08-14-2017, 01:23 PM | #6 | |
09-30-2017, 06:04 PM | #7 |
I swapped out the bulb today with a LED bulb then rewired it to work the way it supposed to. I took the brown wire hooked to the black wire that is in the square 4 prong connector which is hot when the ignition is on. The LED is so much brighter.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-02-2017 at 01:30 PM. |
04-05-2019, 10:17 AM | #9 |
I used the wires for my spot lights. The little bulb still works but only when I activate the spot lights. I figured no need for it otherwise because I ride with headlight on.
2017 RPS Hawk. Mikuni carb, 117.5 main, 25 pilot. Foam filter. NGK plug. Upgraded exhaust. 17/45 sprockets. Digital speedo. Full LED all around. U5 handlebar spot lights. 1982 Yamaha XJ1100 Maxim |
