Old 09-29-2019, 07:24 PM   #1
Armycopter   Armycopter is offline
Armycopter's Avatar
Chain Question
I did a search but don’t completely understand the chain options. I would like to keep my current stock sprockets 17/46 but want to purchase a good quality chain for them. I don’t know what “520” or “428” means. Can someone recommend a good quality chain that wont break the bank for my stock sprockets? The chain that came with the bike stretches like a rubber band and I am concerned about its quality. Thanks.
2019 Bashan Brozz 250
2019 Honda Africa Twin CRF1000L
Old 09-29-2019, 07:36 PM   #2
A quick way to check is to measure pin to pin (pitch) A 428 chain is 1/2" and a 520 is 5/8".
2020 Kawasaki Vulcan S
Old 09-29-2019, 07:44 PM   #3
This is the chain I'm using. Just cut to length. https://rover.ebay.com/rover/0/0/0?m...2F321318221273
Old 09-29-2019, 08:07 PM   #4
Armycopter's Avatar
Thanks, how is it holding up for you?
Old 09-29-2019, 08:11 PM   #5
Very well. I have about 2500 miles on it and never had to adjust it except for when I had replaced the rear tire.
Old 09-29-2019, 08:24 PM   #6
Armycopter's Avatar
Thanks Jerry that is a big help!
Old 09-29-2019, 08:28 PM   #7
Hancadam   Hancadam is offline
This is the one I bought for my Brozz, but haven't put it on yet.
https://rover.ebay.com/rover/0/0/0?m...2F322043802661
Old 09-29-2019, 08:43 PM   #8
Armycopter's Avatar
Thanks hancadam, maybe I just got one built on Friday just before quitting time!
Old 09-29-2019, 09:56 PM   #9
JT Sprockets brand is your go to for budget Made In Japan chains and cogs. I'm running their heavy duty dirt bike chain $15 and have a couple different cogs from them as well. I put 5,000 miles on the Bashan stock chain and have 6,000 on the JT. About every 2-3 weeks the stock chain had to be re-tightened and the Japanese version I've adjust only 3 times just to be safe after binding it up whilst riding like a turkey.
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster,
Old 09-29-2019, 10:17 PM   #10
NzBrakelathes's Avatar
I suggest when changing it’s better value to go 520
https://rover.ebay.com/rover/0/0/0?m...2F222121202245
Old 09-30-2019, 05:47 PM   #11
but then you have to change sprockets
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-01-2019, 11:56 PM   #12
Baskt_Case   Baskt_Case is offline
Baskt_Case's Avatar
I was on the fence with this one for a while...
428 Gold X-Ring 130 Links - $40 Shipped
2018 Hawk - Nibbi PE30, Nibbi Intake, UNI Filter, Ebay Exhaust, NGK 4929 (non-Iridium), 428 D.I.D. X-Ring, 15/40 Sprockets, Walmart AGM Battery, IMS Shifter, Full LED Lighting, Digital Cluster, CSC Swingarm Pin, Modified Chain Adjusters, Upgraded Wheel Bearings
** MPH Cruise, ** MPG
