09-24-2019, 07:12 AM | #1 |
Fuel Starvation issue LF 110 GY-3
I have a LF110GY-3 which has a fuel starvation issue.
It is 8 years old and serviced regularly. However I had a split fuel line from the tank to the filter. My service engineer has removed the tank and replace the fuel line direct to the on/ off tap and then new line from the tap to the carburettor. The engine will run for about a mile and then I get fuel starvation and the engine dies. I let it stand for about a minute and then it will start up OK. The same problem happens a mile later. The engineer has removed the fuel filter from the feed and I am wondering if this is causing the issue. Can anyone suggest options please. Thanks Mike |
09-24-2019, 07:26 AM | #2 |
Check to make sure the tank is vented.
09-24-2019, 10:26 AM | #3 |
I'm pretty sure that a Honda Trail 70 clone if I had to guess.
09-24-2019, 12:27 PM | #5 |
Thanks all. Yes it is aDax replica. I will try all the suggestions Thanks all
Mike |
