Old 05-19-2021, 06:30 PM   #1
Rear shock adjustment Brozz
I decided to remove my rear shock of my Brozz 250 ,and tighten the adjustment ring almost as far as it would go. I know its stiffer ,but I figured with my weight it would ride level, but it now feels like the rear is high,or the front low. I rode it, and it goes down the road well ,but I don't want to put unnecessary strain on the front end .Does tightening the rear shock put more weight on the front end ,or am I good with it adjusted the way it is. Thanks
Old 05-19-2021, 07:15 PM   #2
Falkon45's Avatar
So, you raised the preload. You didn't raise the rear end. You reduced the sag you'd normally get. This does cause the front end to work a little harder, as the rear isn't doing at much work. Take a click or two out, and see how it feels. Also, you don't really need to remove the shock to adjust the preload. If your bike didn't come with a shock tool, I can give you a link to some.
