Old 05-14-2021, 10:31 AM   #1
Dean56   Dean56 is offline
Yamamoto 150 quad
Ho folks, just replace carb on my grandsons quad, now wont start unless I give it the starting fluid and the runs great, better than it has in a long time. Have read other forums which said low compression, bad valve lash, blah, blah, blah. If there was low compression how could it run strong once it started? I've rebuilt twin cylinder Onans and when their compression gets lower the will nor run at all or are powerless. I will do a compression test this weekend just to be sure. Any ideas?
Old 05-14-2021, 10:42 AM   #2
If valve lash is real tight, they'll be real hard to start cold, but run ok afterwards. In fact theyll sometimes even start ok afterwards.
Or you might try richening up your idle.
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
