Old 04-10-2016, 09:20 PM   #1
Ichrisbot   Ichrisbot is offline
Left/right play in swingarm on Hawk250
I was making a few adjustments on my bike while it was up on a stand and noticed the play. The rear wheel and swingarm can wobble about 1" left to right. Is a certain amount of play normal, or is there a part that's worn out and I should change?
I was also playing more with the tire clearance from the chain. The bike has been riding well, but I notice the back end feels like it pulls slightly to the right under hard acceleration and kind of favors to the right when riding a wheely. It's slightly aligned pointing to the right, but if I adjust it any further towards center the knobbies really start smacking the chain. Any thoughts on that?
Old 04-10-2016, 11:41 PM   #2
You should not have any lateral movement in the swingarm. I strongly encourage you to remove the swingarm, and inspect the bearings, et cetera. You should also inspect the wheel bearings.
Old 04-10-2016, 11:53 PM   #3
riding a wheely.... That's a two-wheeled vehicle not a unicycle r.wheel bearing shot?
Old 04-11-2016, 12:08 AM   #4
Ok, I think I'll pull that section apart and see what I can find. Hopefully the bearings are easy to come by, and while I have it torn apart I'll go ahead and throw my shinko tires on.
Old 04-11-2016, 12:35 AM   #5
Here is a link to the Swingarm Maintenance Tutorial, which is posted at the CSC website. All bearings and bushings should be intact, and each should be greased before re-assembly of the swingarm.
https://www.cscmotorcycles.com/Articles.asp?ID=310
Old 04-11-2016, 12:40 AM   #6
Here is a link to the Rear Wheel Maintenance Tutorial, hosted by the CSC website. After removing the rear wheel, remove the bushings from the hub. Then remove the rubber dust seals from both sides of the hub. Insert a finger into the hole, and rotate the wheel bearing on both sides of the hub. The bearings should spin freely, without any notchiness. If either bearing will not spin smoothly, it should be replaced.
https://www.cscmotorcycles.com/Articles.asp?ID=290
Old 04-11-2016, 07:19 AM   #7
lee47512   lee47512 is offline
Have you checked your main lug sometimes it actually is the simple things. If you have an air impact hit it once to see.
Lee
2014 powermax 150.
2015 Hawk 250.
Poop happens
Old 04-11-2016, 07:25 AM   #8
Indeed, it's best to first verify the swingarm bolt is properly tightened. However, you should always inspect the wheel bearings, and grease the bushings as well.
In case you are not familiar with replacing wheel bearings, you might enjoy reading the following thread.
http://www.chinariders.net/showthread.php?t=16320
Old 04-11-2016, 09:54 AM   #9
I only checked that main lug with a wrench, so I couldn't get much torque on it. It didn't budge, but I'll have to borrow an air-wrench and give that a try.
And thanks for posting the CSC links, I didn't think to look there! That's another nice benefit to the TT250 I guess.
Old 04-11-2016, 11:53 AM   #10
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
You will be surprised to see the hawk actually uses sealed wheel bearings.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 04-11-2016, 12:18 PM   #11
That's great. Do you have any photos of the Hawk's swingarm bearings? I might be wrong, but it appears the CSC TT250 uses bushings surrounded by rubber in the swingarm. If this is true, and the Hawk employs sealed wheel bearings in the swingarm, the Hawk has a superior swingarm.
Old 04-11-2016, 01:09 PM   #12
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
The Hawk uses bushings as well. Apparently grease is the rarest of commodities in the East as my Hawk was shipped with a bone dry swingarm assembly.
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 04-11-2016, 01:45 PM   #13
dpl096   dpl096 is offline
dpl096's Avatar
bearings
The overall added expense for a set of bearings would have been minimal at the production point.... I prefer the bearings as well.
Old 04-11-2016, 02:05 PM   #14
A certain amount of flex from the bushings is normal, but not play. I've not found China bushings to last, so I've replaced them with Japanese bushings where I can. It involves removing the existing bushings, measuring them and then searching for identical measurements online.
I once took a wasted quad swingarm bushing to a Yamaha dealer, and he happily brought out the parts bin that contains all of the bushings he had. We found a match, which was a swingarm bushing from a Yamaha PW80 dirt bike; it was much better quality, and it was a $7.00 solution (at the time). I've shared that part number on this forum several times, and many forum members have had good success with that Yamaha bushing in China quads.
I'm saying all of this to encourage members to share similar info as they find it. If you decide to go on a search for new bushings and you're successful, please tell us.
Old 04-11-2016, 02:44 PM   #15
Mudflap   Mudflap is offline
More often than not I've found the swing arm pivot bolt left loose by the factory or owner. Some seem to think because there is no bearing in there that the inner bushing sleeve is supposed to twist on the bolt. It's really designed to twist the rubber and not twist on the bolt.
