09-16-2019, 09:52 AM | #1 |
Hawk 250 Fork Seals
I just want to confirm that these fork seals fit the Hawk 250 in case anyone was looking for an exact replacement. I changed them and fork oil Saturday morning. 125+ miles and no more leak. Also did my oil change and checked valve adjustment. They were spot on.
Replaces OEM: Honda (91255-446-013) https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-02-2019 at 05:32 PM. |
09-16-2019, 10:34 AM | #3 |
220ml of ATF works perfect for my weight. 175lbs. soaking wet. lol
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 09-16-2019 at 11:36 AM. |
09-16-2019, 11:42 AM | #4 |
Is there a body weight to ml ratio or guide?
Example - I'm 210 lbs .. what would be a recommended amount of ATF ml ? |
09-16-2019, 12:06 PM | #5 | |
09-16-2019, 07:52 PM | #6 |
You can adjust the pre-load in the forks. There should be a spacer in the top of each fork. If not, add one to each fork. PVC is fine for this. If there are already ones in there, go longer to increase the pre-load.
09-16-2019, 08:45 PM | #7 |
You're already getting some "air suspension" when you up the fluid levels. I know this from measuring before and after with my weight on it. I added 9 nickels and 210ml of oil to each side and it raised the forks 1.25". And 9 nickels stacked doesn't equal 1.25".
09-16-2019, 08:58 PM | #9 |
Same with Jay's TBR, we initially put 210ml in his and he didn't care for it so we took the factory spacers out and brought the level down to 185ml. You might wanna run it at 160 to 170ml to see if it's more to your liking.
09-16-2019, 09:27 PM | #10 |
My first fork oil change I had 175ml in on fork and 210ml in the other. My Honda manual has 200-210ml. I'll look through some of my other manuals and see what they have. I'm sure 170ml is fine too.
09-17-2019, 08:30 AM | #11 |
Here's what my manual has which has the same specs. as the Hawk forks. The other manuals show anywhere from 140ml to 180ml but the forks aren't the exact spec as the Hawk. Not saying either is the correct amount but basing it on what I took out of my Hawk fork and the specs that match the Hawk forks I went back with 220ml as it works the best with my weight. I don't know the exact specs on the TBR7 forks but they look to be the same as the Hawk. And to be honest it should be measured by the oil level when the fork is compressed. This is something I'll check on the next fork oil change. BTW the oil I took out was nasty for only being in there for 7-8 months.
