01-31-2021, 09:26 PM | #1 |
Wheel Seal knowledge requested
Well, I screwed the pooch on my bearing check. Completely trashed the front wheel seal on the rotor side of the Brozz.
I need a new one. Hoping someone can translate it for me. There is a JL, and then clockwise from the JL, 20, 35, 7, 16 |
01-31-2021, 09:52 PM | #2 |
Can you elaborate on what happened for it to get trashed? I removed the wheel several times and lubed the axle and the sides of the wheel where axle goes thru but never actually removed the cover to look for bearings
01-31-2021, 11:39 PM | #3 |
I tried to pry the rotor side seal out with a flathead precision screwdriver, and having not pulled it out before, pried in the wrong place. Lead to several pries in the wrong places and started ripping the rubber. Just accelerated into me messing it up and ripping tearing it further.
Simple to remove, after finding out where to pry on it. Popped right out when you know the spot lol. |
01-31-2021, 11:51 PM | #4 |
Looks like it is this one:
https://www.amazon.com/16X35X7-EAI-S...2155005&sr=8-3 Last edited by gwowzer; 02-01-2021 at 12:26 PM. |
02-01-2021, 03:47 AM | #5 |
Just measure, like you would measure a bearing. Sometimes googling a number on it will find the seal for you, but more often than not, it won't do anything for you.
It could be a 20x35x7 seal, but you'd have to measure the dimensions being sealed, in mm, to confirm. |
02-01-2021, 06:48 AM | #6 |
Check on the shopbrozz.com parts diagram and if you can't find it maybe try calling Jeff at Peace, I'm sure he can find out the part info
02-01-2021, 07:26 AM | #7 |
Run without the extra seal, the bearing probably has integrated seals anyway. The TT250 wheel bearings do (6201-2RS) RS=roller sealed
02-01-2021, 09:39 AM | #8 |
https://shop.brozz250.com/eshopprod_...l_Assembly.htm
Not sure but perhaps this is the part: Front Wheel Bearing product # 401000-0145A description: SJX 6201RS - $5.00
02-01-2021, 10:58 AM | #11 | |
RS means rubber seal ,2 RS means rubber seal on both sides of the bearing . |
