01-16-2008, 09:08 PM | #1 |
Shudder on takeoff
It seems my bike has developed a shudder on takeoff. When I go from a stop and let the clutch go slowly it takes off and then kinda jerks and goes smoothly from there on out. All other clutch operation is ok, but just the takeoffs, the sprocket is good and tight, and the chain is within spec
Do I need stronger clutch springs, adjustment? |
01-16-2008, 09:12 PM | #2 |
Hi newbie555
What make & model bike?
Thanks, Bruce @ Endless Journey Cycles "Phone Calls Only" ~330-274-0098~ Hours: Tue.-Fri. 10:00-6:00 Sat. 10:00-4:00 EST. Dealer for: Lifan, Crossrunner ATVs. http://www.endlessjourneycycles.net |
01-16-2008, 09:16 PM | #3 |
Newstar DB-200
01-16-2008, 09:20 PM | #4 |
How much free play do you have in the clutch handle? Where the clutch lever hits the mount/perch there should be between 1/8" to 1/4" free play depending on how you like the clutch to release.
01-16-2008, 09:23 PM | #5 |
you mean free play where I Should be able to pull without it engaging the clutch?
01-16-2008, 09:26 PM | #6 |
Yes, exactly.
01-16-2008, 09:30 PM | #7 |
no i dont. But i think if i allowed that much play, it wouldnt engage the clutch fully when pulled in as I had to get an aftermarket handle that doesnt allow as much pulling back
01-16-2008, 09:33 PM | #8 |
Is there an adjustement area on the cable, at the mount for the cable at the engine?
01-17-2008, 10:14 AM | #9 |
Check your rear sprocket bolts (14mm). I bet you will find some or all of them are loose. This makes EXACTLY the feeling you are describing.
01-17-2008, 11:54 AM | #10 |
there is an adjustment on the cable. No, the sprocket bolts are absolutely tight. I just fixed that
01-17-2008, 01:14 PM | #11 |
Perhaps the swingarm bolt? A few members have had issues with broken swingarm bolts and/or lack of grease on the swingarm pivot shaft.
Frostbite "The beatings will continue until moral improves" |
01-17-2008, 01:35 PM | #12 |
Is it the clutch or is the motor maybe stumbling? Just throwing it out there as an option.
01-17-2008, 07:45 PM | #13 |
the swingarm bolt is fine. And it isnt the motor.
01-17-2008, 07:52 PM | #14 |
I wonder what kind of oil it has in it, Might have one that is giving the wet clutch problems.
01-17-2008, 09:39 PM | #15 |
the clutch doesnt slip at all though. it is castrol 10-30 motorcyle oil
