Old 06-10-2015, 03:21 PM   #1
Dionili   Dionili is offline
Turn signals
mine stopped working completely, any ideas on where to check first ?
I tried the bulbs, it's not them...
Old 06-10-2015, 03:32 PM   #2
Check the fuse, flasher, and connections.
Old 06-11-2015, 08:42 AM   #3
Where might the fuse box, and what's a flasher ?
Old 06-11-2015, 09:10 AM   #4
humanbeing's Avatar
WYSiWYG http://item.taobao.com/item.htm?id=36546726632
Fuse http://item.taobao.com/item.htm?id=39518112538 is near the battery
#4 connector
Most stock flasher http://item.taobao.com/item.htm?id=38700497132 are colored in black
Old 06-11-2015, 01:40 PM   #5
JTHSPACE   JTHSPACE is offline
JTHSPACE's Avatar
Not sure on your bike, but it is common practice to hide all this stuff under the seat next or near to the battery. Sometimes under the fuel tank, but not always.
So, remove the seat and find the battery. Hopefully near it you will see an in-line fuse or a set of fuses in a little holder. The "flasher" will be the relay that makes your indicators go on and off. It is usually about 1 inch square or 1 inch round tube. Vibration can cause fuses to blow or relays to unseat themselves, so as Spudrider suggested, gently push and pull connections to make sure they are seated properly.
Go to a supermarket and buy a cheap voltmeter / test meter. A few dollars. This can be used to check that 12v is getting to the bulb or as a tester to see if fuses are blown or not. Can save you loads of time troubleshooting silly issues.
Good luck!
Jeff
Riding bikes for over 40 years
Honda C50 / SS50 / CB125 / CB250
Velocettes (various)
Piaggio's / Honda's / Yamaha's
Raptor . . . . the List Goes On . . . .
Old 06-11-2015, 01:46 PM   #6
Yes, you definitely need a digital multimeter if you are going to troubleshoot electrical problems on your motorcycle. This meter from Harbor Freight (HF) is sufficient for most electrical work on your bike.
http://www.harborfreight.com/7-funct...ter-90899.html
You can frequently find a coupon from HF which will get you that meter for free.
Old 06-11-2015, 04:03 PM   #7
Adjuster's Avatar
Love my Harbor Freight meter. It has fixed electrical on cars, trucks, boats and motorcycles. I paid full price for mine. $3.99 I believe. LOL
Old 06-11-2015, 06:22 PM   #8
#4 connector
found the fuse next to the battery, its fine, still looking though....any other ideas?
Old 06-11-2015, 07:43 PM   #9
Got them working, but all 4 flash at once can't get it to go left or right.... What am I doing wrong
Edit:
It has to be something with the connections up front right now no matter side I set the switch all 4 flash
Old 06-11-2015, 08:41 PM   #10
humanbeing's Avatar
Most signal system in vertical chonda are similar to
Old 06-11-2015, 09:37 PM   #11
I just can't figure it out. I know it's the pins in the front I think but the back is connected properly and when o disconnect the front and hit the switch both side still flash, do I have this thing in hazard mode???!!
Old 06-11-2015, 10:11 PM   #12
humanbeing's Avatar
That gif is for a Honda oldie (NO hazard light)
Does u clicked some mystery switch that's for the "hazard"? If not, left (orange) & right (sky blue) may jammed together somewhere accidentally (PITA to find it 1 by 1 ) .
Old 06-11-2015, 10:13 PM   #13
Shit... I did upgrade them to leds I read some where that I need to change the dash indicator bulb or something... Halp ?
Old 06-11-2015, 10:27 PM   #14
humanbeing's Avatar
http://www.chinariders.net/showthread.php?t=13572
Remove the dash indicator bulb or use "diode kit". Those parts can easily found via some F***ed PCB if had soldering iron ...
Old 06-11-2015, 10:29 PM   #15
The dash indicator doesn't light up at all by the way is that proof of a wording issue ?
Edit: cut out the indicator lights works now, thx!
