04-21-2019, 06:31 PM | #1 |
CSC tt250 top speed with 45T sprocket. GPS confirmed
Today I installed a 45T sprocket ( stock is 50T) and a D.I.D. o-ring chain on my 2019 CSC TT250. I purchased the sprocket from CSC and it came with the correct spacers. The install went smooth and I didnt have to shorten the chain. This mod along with the ebay crf 230f exhaust and mikuni replica carb ( 115 main jet, 27.5 pilot and mixture screw 1 3/4 turns out, foam filter) has really helped the bike become a more road friendly machine. Cruises nicely at 55mph now. Before the engine was pretty much maxed out power wise and buzzy at this speed. Still plenty of power to climb hills in 5th gear also. Max speed today was 68mph. GPS confirmed.
exhaust: https://www.ebay.com/itm/Full-Exhaus...72.m2749.l2649 Carb: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Chain: https://www.denniskirk.com/did/428vx...iew#turntodone Foam filter: https://www.ebay.com/itm/42mm-Air-In....c100148.m2813 Sprocket:https://store.cscmotorcycles.com/REA...p/55-26945.htm
2019 CSC TT250- Mikuni clone carb: 115 main, 27.5 pilot, ebay exhaust, 2 stage foam pod filter, emissions delete , CSC rear rack, 17/45 gearing, Rotella T4 15W-40, 68mph gps confirmed. 300' above sea level |
04-21-2019, 06:48 PM | #2 |
Pretty much spot on what a Hawk does with those same mods and sprocket combo.
04-21-2019, 08:11 PM | #3 |
Cool. I hope this helps others in there quest for the right combo
04-21-2019, 08:22 PM | #4 |
Hmm, I can’t get anywhere close to that. Fully modded and the top speed dropped significantly from stock lol.
Good job getting everything together and making the magic happen!
Bashan Storm: Ebay steel exhaust wrapped, folding shift lever, seat mod, vm26 carb, air pod, dual led scrambler headlamps, windshield mod, led brake/tail light, secondary led brake light (swingarm), Ebay 295mm rear shock, back up CDI (racing unknown), oil cooler, digital gauge cluster, |
04-21-2019, 09:36 PM | #5 |
i have the 47 tooth and see on average the same mph but i have gotten it up to 72mph at 8.5k rpms alot of times 75 if im drafting a car and im not a light rider i weigh exactly 200lbs
try to really dial in your jetting im guessing your still a little lean the amazon exhaust likes to break in and burn out the packing after a while and will lean the bike again if you havent already repack it with some high quality exhaust packing i used moose pack that also helped quiet it and gain some top end
04 flywing 150 05 flywing 150 07 gasgas ec200 18 csc tt250 / foam filter mod, amazon exhaust, mikunki carb, 47tooth sprocket, o ring chain, stereo system, amsoil oil, honda 10w fork oil, tusk bars and brush guards.... more to come |
04-21-2019, 10:21 PM | #6 | |
Thanks for the repack info. Its definitely been a learning curve getting this thing dialed in. My biggest concern is being able to run with 55-60 mph traffic and I have accomplished that without ringing this little bike out. Oh and i have yet to hit 8.5k rpm! Still a little shy about max rpm b/c its new.
04-21-2019, 10:33 PM | #7 | |
