10-27-2018, 09:17 PM | #2 |
I'd like to see this a couple ways. Stock, then new exhaust, then head ported and new carb. It would be a great data base for the gear heads.
I'm in the sticks no dyno's around. Heck were luck the state roads are paved !!!
10-28-2018, 11:38 AM | #3 |
I would like to see the difference in "regular" porting/polishing, and after adding the "outside the box" finishing touch I like to use
10-28-2018, 11:41 AM | #4 |
Didn’t Dan The Man get his old bike on the dyno ?
11-04-2018, 08:22 PM | #5 |
I have a dyno. Just did mine stock. The stock bike did not like the 800lbs drum. Just got done porting the head three angle valve job. Also cleaned the stock plpe out. When i get it back together i'm going to tune it on the dyno.
11-08-2018, 05:32 PM | #6 |
I wanted to Dyno my Hawk but my buddy that had one had shut down his shop and sold the dyno before I could. Did you shave any off the head? If so, how much?
I'm using the butt dyno. Porting and decking the head made a world of difference.
