10-13-2018, 11:47 AM | #1 |
Plug reading
What your critique on this plug? It's the NGK Iridium dr8eix, thanks.
Kirk |
10-13-2018, 12:04 PM | #2 |
I would say lean
10-13-2018, 10:14 PM | #3 | |
10-14-2018, 11:00 AM | #4 |
That overly rich condition I believe is a pilot jet drilled to 0.0185" (measured), and I set the fuel mixture screw to 1 1/2 turns out and left it there. Most of my riding at the house has been 1/4 throttle or less while break-in. I have not adjusted the fuel mixture screw since. Don't mind it a little rich down low, cold it starts right up 1/2 choke every time. This is what I use to read plugs, best I have found so far...
Kirk |
10-14-2018, 12:32 PM | #5 | |
10-14-2018, 12:40 PM | #6 | |
10-15-2018, 05:42 PM | #7 |
Just reading your plug tells me you're Hawk is going to have a long life and happy life. Looks good
