11-01-2018, 02:29 AM | #1 |
CG 250 Rekluse Cluth Auto Clutch?
Okay, so a rekluse clutch is over priced and can cost half as much as our bikes, have anyone tried to install one?
Since the trails I ride are pretty nasty, an auto clutch can really come in handy. Anyone know if the CG250 engine clutch is compatible with anything? If the rekcluse clutch ring drops in, it might just work
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair . Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2 BSR Chronicles - "Project leads to more projects!" Yamaha WR250R Suzuki GSX-R 600 |
11-01-2018, 03:45 AM | #2 |
both my bikes have rekluse clutchs in them... even though rekluse
dosn't make clutchs for them... XT660 I had to widen the spaces between the basket fingers .3mm But the TTR250 was a drop in fit after I made a whole new clutch basket from 7075 alloy... I used YZF/WR 250 & 450 EXP 2 units both with the heavy wedge kits.. It canbe done... dose help if you have and can use a lathe and Mill... but I'm lucky as I have all the gear either at home or work and i'm a tool/die maker by trade... find out if a honda friction plate from a bike that rekluse make a EXP unit for will fit in the hawk clutch basket...or is that close that it can be moded easy... always set / adjust the unit on a hot motor... cold thicker oil gives a false setting when the oil heats up the unit slips to much.. build adjustable clutch arm stops... useing the cable as rekluse state is a joke... get finer setting and they are constant... ...
09 XT660R ... 06 TTR250 ... 80 Montesa H6 125 Enduro... 77 Montesa Cota 348 MRR "Malcom Rathnell Replica"... Current resto projects.. 81 Honda CT110... 80 Kawasaki KL250A1... 11 Husaburg TE125 enduro... "sold" along with another 31... Lifan 125 Pitbike.. "stolen" ... KIWI BIKER FORUM...... http://www.kiwibiker.co.nz/forums/content.php All the best offroad rides in NZ... http://www.remotemoto.com/ E-mail... xtpete1@gmail.com Last edited by pete; 11-02-2018 at 08:13 PM. |
