Old 07-24-2023, 03:58 PM   #1
DesolateSun   DesolateSun is offline
Question Help With Tao Rhino Sprocket Upgrade
I'm new to owning and working on OHVs. I am trying to change the ratio of my stock chain and sprockets, as I heard it would provide much needed torque for hills. I don't have a lot of cash right now, so I was thinking of just changing the front sprocket to an 11 tooth. Would this work?
https://www.whygostock.com/taotao-rh...ront-sprocket/
And then when I get more cash change to a 37 tooth rear.
Thanks, I'm new to all this.
Old 07-24-2023, 09:13 PM   #2
Mudflap   Mudflap is offline
In order to get the gear ratio I wanted I switched to a 428 chain, a 40 tooth rear sprocket from a Taotao ATA250D, and a 12 tooth front. Perfect for the riding I do.
Old 07-25-2023, 12:36 PM   #3
I was aiming for a 3.3 ratio also based on post searches I found of yours and a few others. But whats the 438 chain. Is that smaller links than the stock?
Old 07-25-2023, 12:51 PM   #4
Yes, 428 chain has smaller links. Also note that the 12 tooth sprocket cannot be mounted with the standard locking ring. It'll need a spacer and snap ring instead.
Old 07-25-2023, 01:50 PM   #5
Do you know where to buy steel rear sprockets for the rhino?
Old 07-25-2023, 02:20 PM   #6
I ordered it from Taotao's parts place, I think it's called parts kit.com. Stock sprocket for a Taotao ATA250d which was the predecessor to the Rhino. 40 tooth steel, about $20 when I bought one a few years ago.
Old 07-26-2023, 12:38 PM   #7
I assume if I change to a larger sprocket, I will need a new larger chain? How do you know what size to buy? Say I go with the 11/37 in 530 chain. How does that change from stock?
Old 07-26-2023, 02:46 PM   #8
I can't tell you how many links you'll need for the 530 setup but the 428 setup on mine uses 118 links.
Old 08-17-2023, 03:42 PM   #9
Ok, you convinced me. I'm going with the 428 chain 118 links, sprocket 12 front/40 rear.
What kind of retaining device do I need for the front sprocket?
Old 08-17-2023, 07:04 PM   #10
For the 12 tooth 428 front sprocket you'll need a spacer to fit behind it. I cut the teeth off an old sprocket, it makes a perfect spacer and prevents anything from rubbing on the seal. Then you'll need a snap ring to hold the new sprocket on the countershaft. I fit 2 standard snap rings into the groove. I vaguely remember the snap rings being 5/8" but best measure to be sure. They aren't a tight fit but they don't need to be.
rhino, sprockets, tao
