possible way to cheat...
I agree... Has to be removed and cleaned out. Its really not a terrible job as far as dis-assembley goes... However im sure getting to it on the bike is no easy task. Extensions go a long way., Especially the bendy ones!
You might can cheat a bit by remove the fuel line and inserting the straw of the carb cleaner into the fuel line inlet into the carb. Close your eyes and let it rip. Open the choke and close the choke while shooting the cleaner. Its an easy way to cheat... Cause if you can get it to stay running and idling ok you can run some "seafoam" or "carb cleaner" through with some higher octane gas thats clean. Its worked for me in the past. Good luck! |
