04-19-2015, 06:56 PM | #1 |
LF200 tank grounded?
Hi, Is this bolt for a ground? I grounded it thinking it might be.
And is there a spacer between the rear fender and the bolt hole? It's for the rear rack. It was all in a box when I picked up the bike. If anyone can take a close up pic of the rear rack that would be helpful. Any help would be appreciated. |
04-19-2015, 07:09 PM | #2 |
That bolt is for a rubber strap to hold the back of the tank down. Ground wires attach to where you have the other ground wire attached.
04-19-2015, 07:16 PM | #3 |
The hole in the rear fender cover is just for a button head screw to hold the cover in place. The rack attaches to where dual shocks would attach and where the muffler attaches as well as across from it.
04-19-2015, 07:22 PM | #4 | |
Thank you |
04-19-2015, 07:25 PM | #5 | |
Thank you |
04-19-2015, 08:10 PM | #6 |
The strap has a wire bail on both ends. The other end hooks to the little hook just in front of the upside down U shaped bracket that the seat hooks to.
04-19-2015, 08:11 PM | #7 |
If you can't figure it out or find a pic I'll go take one and post it.
04-19-2015, 08:30 PM | #8 | |
I will let you know. |
04-20-2015, 11:19 AM | #9 |
On my Lifan, I cut a piece of tube to act as a spacer in the fender hole, and I bolted the rack there, along with the two upper shock mount studs. My bike has a monoshock, but the twin shock mounts are there.
My rack is custom, and may not mount like yours.
