10-27-2018, 10:17 PM | #1 |
Hawk rear brake switch
Just wanted to share this, I found a brake switch for the rear brake light that works. The oem switch has some issues like not working consistently. Best of all no soldering, just depin connector. It's a little tricky getting the threads started because the rubber boot on top hits the frame so be careful not to cross thread.
10-28-2018, 09:56 AM | #2 |
I run that one to. Great setup!
2018 storm 250 |
10-28-2018, 01:00 PM | #3 |
Dirty Birdy.
I had the same idea but I wasn't gona take it apart to find the size out. Thanks !
02-09-2019, 09:47 PM | #4 |
UPDATE: switch has failed. does not respond to pressure anymore .
02-10-2019, 01:34 AM | #5 |
Cheap pressure switches leak causing brake failed
Watch out! Better off with the switch n spring set up Both are garbage really but the exterior switch is safet |
02-10-2019, 05:48 AM | #6 |
Or just use a good quality switch like one from Goodridge. I use this one, never had an issue. https://www.amazon.com/Goodridge-Ban.../dp/B000GTV0RC
I had that exact banjo switch on my 75 Goldwing for 6 years without leak or failure. Yes, it does ideally require soldering. I splice the original brake switch harness into this harness, solder and shrink wrap then tape and loom it. Gives a nice long bit of wiring to the connector to route as you need and you can shorten it up as needed before finally soldering the wires together.
02-10-2019, 10:56 AM | #7 |
Cool guys appreciate it. I have only had probs with mine when it is goes out of adjustment but it happens regularly so this my be a great idea for me. one less thing to worry about.
