07-07-2016, 09:45 AM | #1 |
Clutch free play?
Sorry for the dumb question, but I'm a newbie and I did a few searches here and on Google, but I couldn't find an answer. If my clutch is not engaging all the way, i.e. the bike acts like it is still in gear even though the clutch lever is fully squeezed, I need to decrease the clutch free play, correct?
2016 CSC TT250 |
07-07-2016, 11:17 AM | #2 |
you mean not disengaging. Yes, take up some of the play, but, it may need to drag a little cold to be properly adjusted hot.
07-07-2016, 05:09 PM | #3 |
Thanks for clearing that up for me!
Sorry, I thought when you squeeze the clutch lever you are engaging the clutch.
2016 CSC TT250 |
07-07-2016, 05:17 PM | #4 | |
07-07-2016, 05:21 PM | #5 |
When you squeeze the clutch lever you are separating the friction disks (part of the clutch assembly) which disengages power delivery to the drive sprocket. One could see that as disengaging the clutch. Clutch engagement is letting go of the clutch lever (friction disks make contact and apply power delivery). I'm finding that I have to eliminate all free play in the clutch lever when cold in order to improve finding neutral when hot. With these air cooled engines, the expansion rate is high enough when hot to affect the free play compared to when cold.
07-07-2016, 05:22 PM | #6 |
If you think about it this way, you'll never get confused again. If you have to squeeze the clutch lever to engage the clutch, that means you have to hold the lever in all the time you ride. Right? So when you release the lever the clutch must be engaged, because you are moving.
07-07-2016, 05:24 PM | #7 | |
2016 CSC TT250 |
07-07-2016, 05:35 PM | #8 | |
It appears eliminating free play is what I need to do too because I had the issue when the engine was hot.
2016 CSC TT250 |
07-08-2016, 11:16 AM | #9 |
Don't shoot for eliminating freeplay completely; try to at least have some slack in the cable when the lever is released.
07-08-2016, 11:46 AM | #10 |
If the cable is too tight it could lead to problems, but only minimal free play is required. The oil type and condition can make a big difference on clutch operation so if it's got crappy or old oil in it change it out. If nothing simple fixes it it may have warped clutch plates.
07-08-2016, 12:11 PM | #11 | |
No freeplay and when the clutch heats up it will not completley engage and will slip. This makes it heat up more and slip more. Then it will fail, and contaminate your oil no extra charge. I made this mistake on a Honda Shadow ACE 750 many years ago. Cost me a clutch and an oil change.
Happy to serve. |
