12-29-2018, 09:34 AM | #1 |
Hawk 250 Throttle Cable Routing
My engine RPM goes up significantly when I turn my handlebar to right full lock. I have tried routing the cable differently but there are not many options. Any tricks to routing the cable? Thanks!
12-29-2018, 09:40 AM | #3 |
It sounds like a pintch, like you're pulling the whole cable from the top of the carb.
Watch the bark busters also (if you have them) they cam 'hold' the throttle sleve in place when it turns.
