Old 01-25-2019, 07:08 AM   #1
pete   pete is offline
pete's Avatar
Was to easy...
The 1980 KL250 rebuild/restore was going well...
then this... this is the first of 4 sections I have to remove...
and the dam metal is only 1mm thick...
Be a real bastard to get it painted... decals on to have it start
to leak a few months down the track..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 01-25-2019, 01:53 PM   #2
After you weld in another 1mm piece, have you considered laying another strip over that? I have an old XT350 tank I'm doing that to; it'll have an armored look when I'm done, and hopefully take twice as long to rust through again.
Old 01-25-2019, 02:15 PM   #3
ben2go   ben2go is offline
Braze it back together instead of welding it.
Old 01-25-2019, 04:48 PM   #4
pete's Avatar
I put a 2mm patch on the inside with a 10mm overlap..
weld a long bolt to the patch centre to hold it in place..
I just run the mig around it... I done the welds vertical down
fast weld and keeps the heat down..
all the rust pitted areas I am going to flow body solder over..
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 01-26-2019, 01:49 PM   #5
Body solder in the US is lead. Is it the same there in NZ?
Old 01-26-2019, 03:36 PM   #6
pete's Avatar
Yes.. pretty sure it would be the same thing or that close it doesn't really matter..
not very common these days.... wonder where to get it.. A question for Mr Google I think ..
Just found this online...
09 XT660R ...
06 TTR250 ...
81 Honda CT110...
Old 01-26-2019, 05:03 PM   #7
You can generally get body solder in two flavors. The traditional lead based, or the "safer" high tin type that requires a bit more heat.
