05-15-2019, 12:12 AM | #1 |
Swing Arm Help!
I pulled my rhino 250's swing arm off tonight as i noticed it had some play well i see the needle bearings are bad and the inner shaft is wore on ends where the bearings ride. Does anyone know if they sell the insert shaft? I'm not paying for a whole new swing arm.
05-15-2019, 02:16 AM | #2 |
05-15-2019, 05:42 AM | #3 |
I just pulled my Rhino swingarm apart yesterday to replace the bearings with those I bought from Partskit last year. The OD on the ones they sent was about 1mm too small so I cleaned up and reused the originals. There was some wear on the tube but not too bad. Not a great design. They should make it easier to grease them and put seals on the ends to keep out the dirt.
05-15-2019, 11:58 AM | #4 |
Bushings swingarm
Use the poly rods for the bushings … last forever...
05-15-2019, 08:08 PM | #5 |
I Just ordered a new set of bearings i'm going to try that first. Any type of machining around here cost a arm in a leg. So ill try to hold out on that. Seeing the rod on partskit is special order and 2-8 weeks.
05-19-2019, 01:30 PM | #6 |
Poly rods
any place that sells the plastic rods and stuff has them in stock.. check your local supplier... or I know a lot of people live in small towns .. so pick them up when you go to a major town … city... about $10.00 a rod or piece... I have not check ebay or so..
