Old 08-06-2019, 01:52 AM   #1
Whitelx1   Whitelx1 is offline
Jonway YY150T-12 will not crank after trying to jumpstart
I tried to jump my sons scooter and all of a sudden it stopped cranking. Right away I tried to start it off the relay and it started. I am mechanically inclined and I am stumped on this one.. I am not getting power out of the starter switch but there is a ground.
I switched the starter switch with the horn switch to see if that would help and same thing.
And yes I am pressing the back brake to compete the circuit .
I know some might say it is a broken wire but at this point not sure where to begin looking ..
Any ideas on this and is there a way to bypass the switch.
Also the kill switch is off, just wondering if there is a fast fix for this ..
Again no power to the starter switch .
Thanks Again
This is based off a GY6
Old 08-06-2019, 05:44 AM   #2
pete   pete is offline
pete's Avatar
diode...
the starter system on a motorbike is quite different to a car etc..
the starter button is so small it can not handle the current draw
form a DC system... so they run AC though the button from the
rectifier...the diode stops the DC and AC current coming in contact with each other..
depending what/how you jump started it you could have burnt the diode out..
if you bridged DC & AC current...
or burnt out start button....
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 08-06-2019, 10:38 AM   #3
tortoise   tortoise is offline
No mention of checking fuse . . typically located in battery compartment?
