03-27-2009, 12:47 PM | #1 |
Pulse Adrenaline 125cc The Project Begins
Any of you guys familiar with the Chinese dirt bikes also known as the GY series that use the 157FMI Suzuki engine?
I’m currently riding a Pulse Adrenaline and they come as a 125cc but some places have similar bikes that use the same engine available in 200 and 250cc and I’m trying to find some one who can supply me with a 200cc barrel piston and head. My plans are as follows….. 200cc bore kit with matching piston and head 30mm Flat slide carb Playing around with various sprocket sizes Other non performance related mods planned are some gold Renthal bars and a gold Renthal chain, custom paint work in Jazz Blue, Projector style twin front lights and LED indicators |
03-27-2009, 01:21 PM | #2 |
That looks like a Qingqi bike... Where are you located?
"Be excellent to each other" "We are all human. Let's start to prove it!" |
03-27-2009, 01:30 PM | #3 |
Yup, Don't look like any GY I have ever seen...Nice bike.
03-27-2009, 01:41 PM | #4 |
I'm based in the UK but dont have any problems with buying parts from over seas.
It is a GY the model number is XF125GY-2B heres a few more pics |
03-27-2009, 02:38 PM | #5 |
Is there a tag on it that says who manufactured it?
03-27-2009, 02:44 PM | #6 |
Its made by Pioneer
03-27-2009, 07:30 PM | #7 |
Possible to use a dr200 head and cylinder.
Allen
03-29-2009, 09:53 AM | #8 |
Is that a "It may be possible" or it is possible??
03-29-2009, 02:26 PM | #9 |
03-29-2009, 07:10 PM | #10 |
That would be a maybe on the dr200 parts. It would take some comparing to be sure.
Allen
03-29-2009, 07:39 PM | #11 |
These bikes are related to the Qingqi, but Pioneer might be an assembler of bikes using Qingqi parts. Or it might be a Qingqi. However, a good source of the Qingqi knowledge is member 'Forchetto' who knows alot of "stuff" about these bikes.
03-30-2009, 06:26 PM | #12 |
It's made by Shandong Pioneer who are part of the Jinan Qingqi Group since 1995.
It's very close to the bikes made by the main factory with some differences such as rear disc brake, slightly different side panels, and the rear wheel hub and sprocket assembly is compatible with Honda CG and CB125's, rather that the Qingqi's Suzuki DR200 rear wheel components. 200 cc parts might be available in the UK from the people that supplied bikes under the names of Sinnis Apache QM200GY and Superbyke RMR200. The bottom has dropped out of the 200 cc market in the UK, but those importers should have the parts you require even though they might not market the 200 cc versions anymore. Sinnis UK, for example, still market the Blade 200 with that engine: http://www.sinnis.co.uk/wp_products_tech_blade_200.php Superbyke UK still has the RMR 200 in its site: http://www.superbyke.co.uk/ You might find it difficult to put a flat slide carb in it, unless you can find an adapter with a flange bolt-to-bolt distance of 65 mm. In any case the bore of the inlet port in the head is only 28mm (200cc head). This is to suit the 28 mm Mikuni BST28 the 200 cc models come with. The Suzuki DR200 head does have a 31 mm inlet port bore to suit its Mikuni BST31 carburettor. I notice your plans don't include a different exhaust and yet this is what makes a considerable difference to these bikes. A cheap and effective mod is to fit this can from Xian Racing in Newport, Wales, UK. Apart from the weight saving and increase in durability (it's stainless steel), it eliminates the restrictive catalyser built into the factory silencer, and gives a very worthwhile increase in power and throttle response. Sounds great as well... See it here: http://xian.west-wire.co.uk/index.ph...d&productId=58 A quick mental calculation tells me that the overall cost of all these mods will come to something like 50% of the cost of the bike, excluding labour charges. We know how much Chinese bikes depreciate...is it a wise move?.
Jincheng Monkey JC50Q-7 (two of them) Skyteam Dax replica ST110-6 (two of them) Zongshen ZS125-43 Qingqi QM200GY-BA Super Motard Yamaha Virago XV1100 Triumph Bonneville SE Qingqi QM110GY PGO Bug rider 250 Buggy |
03-31-2009, 04:14 PM | #13 | |
I’m surprised how much different the filter has made it feel seeing as the standard air box didn’t look that restrictive, but with the new filter acceleration had greatly improved and hill climbing is much better as well. I will be contacting Superbike or Sinnis in the near future to get prices on a 200cc cylinder, piston, head & cam although I’m not sure if a 200cc head will be any different from my 125cc version? As far as carbs go I’m fairly sure I will be able to get a nice flat side to mate up and if i cant it wont be that hard to fabricate something. I’m a big fan of flat slides ever since I fitted one to my race tuned GY6 engine. The sprocket set up is a strange one it would appear that the rear sprocket is indeed a Honda CG type set up but the front sprocket looks more like a Suzuki DR jobby Anyways until i get some pics up of my progress on the Pulse Adrenaline heres a few pics of my last project which started off life as a Lambretta Pato AKA Znen Firenze AKA Lance Milan 125. The Project included the following Custom Paint Work Custom Exhaust 170cc Bore Kit High Compression Piston Head Ported & Polished with larger valves Up rated Cam Prodigy Tourqe Driver Prodigy Race Clutch Prodigy Race Clutch Bell Prodigy Teflon Variator Various Tourqe Springs Dr. Pully Sliders Bando ECU & Coil Gear Up Kit Basic Nitrous Kit 30mm OKO Flatslide Carb with pumper jet Performance intake Manifold |
03-31-2009, 06:10 PM | #14 |
That Lammy looks the business... :P
The dealer should have the spares list and he can check up wether the two heads have the same number. They might be different in the arrangement of the Air injection gubbins. The 125 has the air port for the emissions gear on the head itself, but mine has it on the downpipe. Both can be blanked off. The front sprocket might be a problem. I tried to adapt a DR200 Suzuki one but found the splines and method of fixing different. Aparently mine uses sprockets from a Suzuki TS125ERN /ERT /ERZ and even so they have to be machined to remove the centre part for it to fit on my Qingqi. In the end I just changed the rear one. There's a post explaining my DR200 520 chain conversion cock-up here: http://www.mychinamoto.com/forums/showthread.php?t=534
03-31-2009, 06:51 PM | #15 |
What size rear did you go for and where did you get it from? also what MPH you getting?
I take it your bike is already 200cc?
