Old 07-12-2016, 02:53 PM   #1
MichaelJFoy1   MichaelJFoy1 is offline
Looking for parts for this bike MXF-150 4M
I broke the glass head lamp for this bike, anyone know where I can order a new one from? Also the electric seems to be acting funny. The brake light/tail light is constantly on and headlight and turn signals are not working, I replaced bulbs.. are there some fuses that I can't see aside from the main battery fuse ?
Old 07-12-2016, 03:06 PM   #2
hertz9753's Avatar
http://chinariders.net/showthread.php?t=15845
That guy has one of those bikes.
Old 07-12-2016, 03:41 PM   #3
I saw that... those pages came up in all Chinese for me
Old 07-12-2016, 09:09 PM   #4
humanbeing's Avatar
The headlight maybe similar to WY125-A/C/F... (aka GL125 in Honda http://world.honda.com/news/2004/c041209.html) / GL145 (indonesian) which the measurement should be as http://item.taobao.com/item.htm?id=531213094654
http://www.dansmc.com/electricaltesting.htm
No matter the bike's origin, electric(s) works on the same principle. Old bike's s/w(s) ALWAYS moisture trapped / stunk... Contact cleaner maybe works...
Most stock chonda (as those Honda they copied from) had 1 fuse near the battery ONLY (Used bike = unknown. PO(s) may improves it from here & there)
Old 07-13-2016, 06:49 AM   #5
Awesome, thank you ! The head lamp looks similar, I will measure and check dimensions to make sure. The connection spray is a good idea, I took a multi meter to the wiring harness, battery has a charge and the wiring harness under the head lamp that runs the circuit for headlamp and turn signals has no charge ... it's hard to trace the wires through the body of the bike due to multipul wire wraps and tricky running. Is there a wiring diagram or manual that is for this bike by any chance? Thanks user!
Old 07-13-2016, 08:44 AM   #6
humanbeing's Avatar
http://chinariders.net/showthread.php?t=14188 | https://josemaco.files.wordpress.com...h-62ktjam5.pdf | https://picasaweb.google.com/iondogck/12502 (Focus on the #s of 150 wears limit, ignore the words)
Generic color code: http://fanyi.baidu.com/transpage?que...e=url&render=1
Old 07-14-2016, 06:45 AM   #7
All of the pages are 100% Chinese, I'm having a hard time interpretating and navigating through the page
Old 07-14-2016, 08:14 AM   #8
Bruce's   Bruce's is offline
Not sure about yours ,but many motorcycles use ac voltage to run the headlight not c like the rest of the bike .bike must be running for the headlight to work
If you cannot find an original ,there are several aftermarket headlight assemblies that you can use .
Old 07-14-2016, 12:49 PM   #9
The rear light is working (constant on, doesn't change with the pressing of the brake ) and the small bulb under the main bulb for the headlight, same assembly which is why I find it odd it doesn't work . Stuck the multi meter in the wiring harness and only one of the wires had power (the small bulb I'm assuming )
Old 07-14-2016, 03:11 PM   #10
Okay update.... you were right about the headlight . I did not try that while it was running... after doing so it turned right on... so now just getting the turn signals to work, and figure out how to get the break light off a constant on. Thanks user !!!
Old 07-14-2016, 03:39 PM   #11
Got break light all fixed ! Now only issue is the turn signals
Old 07-14-2016, 08:28 PM   #12
Progress!
