10-30-2010, 10:32 PM | #1 |
2 Gio 125cc pitbike, prep info
Hi, im a new china bike owner, ive got 2 Gio bike 125cc on its way. I would like to know what are the stuff that I should buy to prep my new bikes. Which engine oil, filter oil, spark plug, grease, tools? Basically I wanna be prepared to prep them.
Any other tips or links to articles... Thank you Alex |
10-30-2010, 11:01 PM | #2 |
On my 125cc i used Castrol 10w/40 motorcycle oil, a NGK CR7HSA spark plug, K&N air filter oil and make sure you loctite everything, after a bit i changed the chain to a DID, much better than the stock chain, other than that it was a great bike till i sold it so i could upgrade to the X31.
10-31-2010, 12:26 AM | #3 |
Welcome! Love your screen name. I'm guessing your phone number is 18436572.
Wayne has pointed you in the right direction. Please let us know how the bikes work for you.
10-31-2010, 12:38 AM | #4 | |
I will keep you guys posted as soon as UPS show up with my Orange and Black GIO 125cc dirtbike, I cant wait!!. |
10-31-2010, 12:42 AM | #5 |
Love the '73! Hate the awful bumpers on the '74. Did you do anything special with your rebuild?
10-31-2010, 12:50 AM | #6 | |
Vortec heads, edelbrock RPM intake, scorpion roller rocker, comp cams XE274 camshaft, hedman hedders, edelbrock AVS carb. So its a nice combo, puts out 380HP/454LB-FT, its not a 10sec 1/4 car Here is a picture:
-73 Camaro -2010 GIO 125cc dirtbike -2010 GIO X33 140cc |
10-31-2010, 12:59 AM | #7 |
That's really nice. 8)
Love the Torq Thrust look. Did you use beehive springs with the Vortecs? IIRC, .490 is on the edge of coil bind with stock Vortec springs. I'll bet it starts and runs nicely with that vacuum secondary.
10-31-2010, 01:03 AM | #8 | |
Im still debugging the engine as I dont know shit, I rebuilded my engine using message boards and dvds
10-31-2010, 01:06 AM | #9 |
We all gotta start somewhere.
Did you have to cut the valve stems down? Are you running a stock type HEI?
10-31-2010, 01:11 AM | #10 | |
http://www.chevyhiperformance.com/te.../photo_02.html Right now it has a stock HEI, as I had issue with my Mallory HEI, but this winter I will be reinstalling my Mallory unit.
10-31-2010, 04:30 PM | #11 |
Sorry, I said stems but I meant guides. It looks like you used the guide cutter as well as the spring seat cutter. How did you measure depth?
Have you tried to dial in the HEI? I've had excellent results with advance kits and trying different weights and springs. The last one I did worked best with one light spring and one medium spring; you end up with an average between the two. I set the base timing at 12 degrees BTDC, and I got strong acceleration with no detonation. Two light springs rattled like rocks in a coffee can and two medium springs felt like there should be more power. I never dyno'd it, I only used seat of the pants. You can optimize your HEI with a $20 advance kit and a timing light. If you're lucky enough to have a dial type light, you can even tailor the advance rate. We've really drifted from your original topic, but this topic is fun too.
11-01-2010, 12:26 AM | #12 | |
Didnt dial the HEI, i just install my stock HEI since I had issue with Mallory Coil, so the spring are stock, I just set the initial timing at 12deg. I will play aroud with the springs during winter.
11-01-2010, 12:45 AM | #13 |
Beautiful car. I really like the early examples of that particular generation.
Happy to serve. |
11-01-2010, 12:48 AM | #14 | ||
Let us know how the HEI re-curve goes for you, when the time comes.
