05-27-2016, 08:29 PM | #1 |
Vibration
What have you all done about the vibes at 60mph?
05-27-2016, 09:32 PM | #2 |
I'm getting used to it.
05-28-2016, 12:05 AM | #3 |
Not a problem on mine, yours must be defective.
Oh, and mine hasn't passed 57. |
05-28-2016, 07:19 AM | #4 |
Yours is cb engine and you need to take it easy on that brand spanking new engine.
05-28-2016, 11:08 PM | #6 |
There are different schools of thought on break-in and I've seen strong evidence for getting on it earlier than later. I'm not beating on it, but not babying it either. After some street miles at various speeds/loads I jumped on the freeway to see what it would do and got 57 on flat land. Today I learned that my speedo reads a little low so I may have actually hit a hair over 60, still not what I was told it would do, but I'll wait till it's broken in a bit more. I'll try to remember to do another compression test tomorrow just to see if it's changed any from day 1.
05-29-2016, 12:22 AM | #7 | |
05-28-2016, 01:45 PM | #8 | |
it will be less vibration
2016 TT250 2014 NSS300 FORZA 2014 UN200 BURGMAN |
05-28-2016, 01:45 PM | #9 |
looks nice I went with black but red would have been my second choice
05-28-2016, 01:48 PM | #10 |
Those hawks look great how many miles are on it it should smooth out a bit after break in plus the suspension with break in to and want be so rigid
05-28-2016, 02:08 PM | #11 |
vibration? i have two hawks, neither seems to vibrate to any more than nominal extent and as for what there is at higher speeds seems to me to be from the hardcore full knobby tires. Actually i'm quite interested in seeing the difference with my soon to arrive TT250 with the balanced motor and the more DP tires. And as for speed, get some miles on those bikes first. After 500 to 600 miles they really seem to come to life. 60 t0 65mph is no problem with my 16/45 gearing ,with a lot of throttle left. I expect to bust 70 without drama when i reach 1k miles on the engine,reset the valves, and switch to full synthetic in the case. (and keep that chain clean and lubed! The friction killing Dupont stuff from Walmart can easily get you a couple of mph over a dry/dirty chain).
Seer's First LAW-"FLY THE PLANE!", fail that, and nothing else matters. 12th Law- Consider what marvels you might do if only you had tomorrow to live over again. Third Law-When someone tells you some thing "Can't Be Done", what they're really saying is They can't do it!!14th Law-Just because something "IS", doesn't necessarily mean it SHOULD be.. Eighth Law-The only true personal security is anonymity.Ninth Law-Humans tend to learn very little when speaking.10th Law-Some lives ARE worth taking |
05-30-2016, 05:46 PM | #13 | |
I can tell you, parking the hawk and heading off for a run on the LT brings THE biggest grin to your face, and The bigest "cush to you tush" in motordom!!!!
05-28-2016, 10:37 PM | #15 |
Keep it at 55, hahahahaha
2005 Kazuma Cheetah 200 (Swamp Thing) |
