06-07-2016, 06:54 PM | #1 |
Hawk 250 front wheel assembly
Hi guys. Just got my hawk 250, as you know it did not come with assembly instructions. (Are there any real instructions?) , the front wheel assembly has the silver bushing but when i try to align it inside the forks it seems to be pushing the forks apart too much and keeps the tire from being alligned,
What is the sequence?, main bolt, fork, bushing , speedo assembly, wheel , fork, nut? Any help would be great plugging along on assembly.. Sorry for noob question Thx!! |
06-07-2016, 07:14 PM | #2 |
No problem man!
It should go nut,fork,bushing,wheel,speedo,fork,bolt Also, the bushing will fit into the left side of the wheel. From the perspective of sitting on the bike, if your standing in front of the bike, reverse the order. Hope that helps! Last edited by mq1991; 06-07-2016 at 08:08 PM. |
06-07-2016, 07:25 PM | #3 |
I have questions, what size is that nut, is it available in a nylock nut? Wonder what the tork is, I don't tighten too tight for fear of bearing damage.
06-07-2016, 08:04 PM | #4 |
Unsure of the size, but i believe the manual says 45ft lbs for the front and 65ft lbs for the rear.
06-08-2016, 07:25 PM | #5 | |
want to replace with nylocks one of these days
06-08-2016, 11:32 AM | #6 | |
Welcome! Blue Loctite is always a good idea. As well, if you have sufficient thread sticking out beyond the nut, you can drill a small hole through the axle for a cotter pin. it won't be captured like with a castle nut, but it'll stop the nut from falling off.
06-07-2016, 10:55 PM | #7 |
got it! appreciate it, almost done with assembly. really big help, along with the video on the FAQs i was able to figure almost everything out... was missing the 3 nuts from the back of the Speedo that mount it to the bike, gotta pick those up from ACE tomorrow also.
06-08-2016, 12:03 AM | #8 | |
I picked up this assortment of nuts and bolts, works great when something random goes missing! http://www.harborfreight.com/725-pie...ray-67624.html They work great for non-critical uses, such as fairings, exhaust shields, and mounting your speedo. |
06-08-2016, 11:44 AM | #9 |
Get some of these instead of the regular cotter pins... these are Re-Usable and easy to install/remove each time too
Check your local Home Depot and see if they have them... search for "Ring Cotter" and make sure you look at your local stores for availability http://www.homedepot.com/b/N-5yc1v/N...estoreoption=1
06-08-2016, 01:31 PM | #10 |
never used that kind of cotter ring.
this is the kind I've used the bowtie cotter pins work well too McMaster carr referse to those as locking cotter pins http://www.mcmaster.com/#=12rllxs
06-08-2016, 01:54 PM | #11 |
This video shows the front wheel assembly at the 2 min mark,
06-08-2016, 02:49 PM | #12 |
The bushing I am referring to is at the 2:37 mark, he obstructs the camera for a second, but then its shown inserted into the wheel.
06-08-2016, 03:30 PM | #13 | |
Deleted the misinformation in my post above. |
02-04-2017, 11:51 AM | #14 |
Hawk 250 rear wheel torque
Hello, when I replaced the rear sprocket, I read that the rear axle bolt spec of 65ft-lbs of torque. Has anyone torqued to that. It seems like when I tighten the rear it's just not going to snug up to that. I have everything in place. I just don't want to crunch the rear tubes if not necessary.
02-09-2017, 01:07 AM | #15 | |
