03-28-2017, 05:34 PM | #1 |
RX3 Clutch/Brake Lever Alternatives?
Probably a dumb question, but do we know about any clutch/brake lever alternatives to the stock ones? I dumped my bike doing some adventure riding in the Mojave Desert last month and I've got a lot of play in the clutch lever now. It kinda wobbles up and down freely now (Half inch or so). I want to replace them both with something a bit better than the stock ones, something adjustable maybe. Are just about all levers the same minus the length?
Thank you! |
03-28-2017, 11:34 PM | #2 |
Spanner, check and see if the bolt and nut that the lever pivots on has come loose. Mine has in the past and gives the lever a lot of wiggle. Also see if the lever perch is cracked from falling on it. Back in the day we would tighten the lever perch to the handle bars not so tight that they could pivot out of the way in a crash. but tight enough to stay put just prior too. rj
Live Zong, and Prosper |
03-29-2017, 11:15 AM | #3 |
I did these but you better have monster mitts. Every stubby lever I've seen are for the longer fingered person. I like em, they are shorter and adjustable but even at the closest setting, it's a reach for most.
"Light a fire for a man, and you heat him for a day. Light a man on fire, and you heat him for the rest of his life." 2007 Suzuki DRZ400S (SM convert) 2009 Q Link XP 200 1967 BSA B25 250cc Starfire 2022 Royal Enfield Interceptor 650 2023 Royal Enfield Scram 411 1948 Royal Enfield Model G 350 Last edited by 2LZ; 05-26-2020 at 12:24 PM. |
04-12-2018, 12:16 PM | #4 | |
Hey, which lever is that? Any info on sizing? My buddy has one on his new Versys 300 and I really liked it. Thanks |
