11-18-2017, 09:31 PM | #1 |
Hawk Fuel gauge
The pic below shows when the approx. trigger point is when filling tank and indicating full.
11-18-2017, 09:35 PM | #2 | |
11-18-2017, 09:38 PM | #3 |
For the two bar indicator on the cluster the gas is a little bit higher in the tank and about 62 ohms if I was to read the rheostat at that position.
11-18-2017, 09:42 PM | #4 | |
For the one bar fuel pump flashing on the cluster. This will now occur on my tank with this fuel float position. It still leaves me with gas, But its now more of a need to consider finding a gas station. Last edited by Musictrek; 11-18-2017 at 09:50 PM. Reason: typo |
11-18-2017, 10:08 PM | #5 |
My float triggers a one bar and fuel pump flashing at this float positon. Which is about 64 ohms. I adjusted my wire on the float to set this up. Id say my float has allot of dead space in terms of cluster readout. the changed readout from 3/4 to full is pretty tight. Although the tank is pretty wide at that point.
11-18-2017, 10:28 PM | #6 |
My only concern for a fuel gauge is if the 1/4 tank indicator is accurate, but even I would be a little irritated if it read full for so long. By the time it reaches the level you see as full, that's somewhere between 3/4 and 1/2 full. How much bending did you end up doing to get it accurate?
11-18-2017, 10:43 PM | #7 | |
11-18-2017, 10:50 PM | #8 | |
11-18-2017, 10:58 PM | #9 | |
http://www.chinariders.net/attachmen...1&d=1490834951 Wow, I guess if you compare my old pic to the now adjusted one. I moved it allot. Last edited by Musictrek; 11-18-2017 at 11:02 PM. Reason: added text |
11-19-2017, 10:37 AM | #10 |
11-19-2017, 08:46 PM | #11 |
seems like i remember someone bending the ears on the unit to make it read 10 ohm to 90 ohms
