12-06-2017, 12:14 AM | #1 |
Need ZS GY200 plastics
Looking for a source
(a real source not endless vague alibaba links) For THIS right side cover (dont care about color or badge) Maybe? Unobtainium? Any ideas? Thx |
12-06-2017, 06:42 AM | #2 |
You mean like, this one that I found within 2 minutes of using Google? http://www.chineseatvpart.com/atv-pa...?product_id=86
A trick I have learned for searching for parts is to sometimes search outside of the box and get creative with wording. It also helps to do a little research and see if any other bikes shared body panels, which I have found is fairly common with many chinese bikes. Take the Hawk/TT250/Bashan Enforcer. While there are small styling differences between them, you can take most of the panels and swap them around.
12-06-2017, 12:15 PM | #3 |
Ah yes but note: "out of stock"
i can find a dozen places where the parts used to be or available if i buy 1000pcs... lots of other goodies there tho' |
12-06-2017, 01:26 PM | #4 |
A little pricey but looks like its available. http://www.roketapartsdept.com/ROKET...07a-200-03-33/
12-06-2017, 02:12 PM | #5 | |
Also, note the description lists multiple bikes that it fits. You can try searching those and come up with more results.
12-07-2017, 01:32 PM | #6 |
thanks guys for the info!
Rocketa parts site is spendy but hey it is 12yr old plastics. good point about calling anyway/ stale webpages; i get the feeling some of these sources we see are sloppy and even perhaps not even generated by humans.... |
12-07-2017, 03:32 PM | #7 |
The pricing is a bit steep but not that unheard of either. Hawk side panels through most retailers are right around that same price range. Thankfully the TT250 panels also fit, and you can nearly buy both for the price of one Hawk panel. The Markup on these parts by some retailers is ridiculous.
plastics gy200 |
