Old 12-11-2017, 02:59 PM   #1
Matt Simpson   Matt Simpson is offline
VMC regulator
Does anyone know the wiring on a VMC regulator, it has red, yellow, pink and green wires. I am hooking it to a Lifan 125cc semi auto 4 spd.
Thank You
Matt Simpson
Old 12-11-2017, 10:52 PM   #2
humanbeing's Avatar
Basic color code: http://chinariders.net/showpost.php?...3&postcount=11
Full wave http://mastercircuits.blogspot.com/2...onversion.html system -Pink or yellow as IN1/2 doesn't matters.
Half wave system. Take the multimeter out. Lighting usually in yellow & the voltage is different from charging coil...
Old 12-19-2017, 09:57 AM   #3
I hope I have this correct, The green= ground, Red=power out of regulator, pink and yellow will hook to my yellow and white from the engine and those two colors don't matter witch one is hooked to each other? THANK YOU!!!!!!!!!!!!!!
