06-15-2018, 12:59 PM | #1 |
Worn clutch on hawk 250
I can hear clutch slipping when I gas it and the lever has a LOT of play. I already adjusted it and it's loose again. How do I replace the clutch? Any good guides? What's the best clutch to get? Any special tools needed?
06-15-2018, 01:01 PM | #2 |
While I'm there, the gears tend to skip a bit between 4th and 5th, like there's a neutral between 4th and 5th, what should I do about that? What would cause it? Any performance parts that would be best to use?
06-15-2018, 01:14 PM | #3 |
Which end did you adjust the clutch at? Are you already maxed out on the engine side of the cable adjustment (long threaded section on the right side of the engine)?. I beat on my Hawk pretty hard, and with the taller gearing I was running and my fat butt in the seat I had to feather the clutch a lot, and in 3000 miles my clutch was still working fine.
Follow this clutch adjustment guide for the TT250 and see what the results are. https://www.cscmotorcycles.com/Articles.asp?ID=298 Try that first and see how it behaves. The false neutral between 4th and 5th may be related to the clutch adjustment, or is a separate issue. I just want to eliminate other variables first (clutch adjustment). EDIT: The only other thing I can think of would be oil related. What oil are you running in it?
06-15-2018, 01:25 PM | #4 |
That was the 1st thought that came to my mind. Over 3200 miles running a tall gear ratio myself with no issues.
06-15-2018, 03:46 PM | #5 |
Well I use 15-40 motocraft that I got at Walmart and risolene ring sealer and Lucas transmission slip stop, or whatever, additives. Figured I should. And I adjusted the handlebar side of it maybe that's the problem. But would someone be able to show me how one normally replaces the clutch? Just so I know what to do worst case scenario? And if there's a performance clutch I can add?
06-15-2018, 04:29 PM | #6 | |
06-15-2018, 04:33 PM | #7 |
Umm idk. Think that could've fukt the clutch?
06-15-2018, 05:01 PM | #8 |
No, the clutch won't be bad from it, but drain all of that junk out of there and put some Rotella T4 in there with no other additives. Non wet clutch rated oils and additives often contain moly or graphite, and those can cause the clutch to slip.
Put that fresh T4 oil in there, ride it for a bit and work that clutch, get it nice and hot, drain it out and fill it with fresh T4 again. Once you flush it out then the clutch should start coming back.
06-16-2018, 02:34 PM | #9 |
Also I don't see Jaso certification.
