04-12-2019, 06:23 AM | #1 |
How to oil a 2 stage foam uni filter???
Just curious about oiling a 2 stage foam air filter. Do both the inner and outer foams get oiled? What brand of oil does everyone use?
2019 CSC TT250- Mikuni clone carb: 115 main, 27.5 pilot, ebay exhaust, 2 stage foam pod filter, emissions delete , CSC rear rack, 17/45 gearing, Rotella T4 15W-40, 68mph gps confirmed. 300' above sea level |
04-12-2019, 06:48 AM | #2 |
I just oil the inner...
04-12-2019, 08:03 AM | #3 |
Thank you. Any preference on brand, spray or bucket soak?
04-12-2019, 08:10 AM | #4 |
I use Castrol foam filter oil in a spray can...
don't put it on to thick... ..
04-12-2019, 08:13 AM | #5 |
Same as Pete, Spray the inner foam. I use K&N filter spray that I had laying around. Just a light coat is all that's needed.
04-12-2019, 12:26 PM | #6 |
Maxima and PJ1 brands also make a decent "Foam Filter Oil"
04-12-2019, 01:03 PM | #7 |
I too oil just the inner, most often with chainsaw bar oil because its sticky. Put a few tablespoons full in a sandwich bag, put filter in, mush it around to distribute the oil.
04-12-2019, 01:56 PM | #8 |
I may as well chime in with, only the inner with oil, the coarse outer is there to block the big stuff, but you don't want it to hang on to it either.
I use whatever oil is cheapest. I like the sprays just for the easy of application.
04-14-2019, 07:14 AM | #9 |
I've been using PJ1 in the spray can.
2016 RPS Hawk 250, exhaust, Uni Filter, Mikuni VM-26 clone w/ 120 main & 30 pilot, MSR shifter, 17/45 sprockets, JT chain, digital cluster... |
