03-30-2009, 02:31 AM | #1 |
125 Pit Bike Oil Leak Repair
My son's 125 developed an oil leak out of the left side, and I presumed it was a shifter seal leak until I started investigating further. I figured that the leak was caused by excessive crankcase pressure, so I added a valve cap vent. That seemed to free up some power, but the leak remained.
The photos below show the removal of the flywheel, stator plate and o-ring. The replacement o-ring, part number 91301035003 was about $7 at the local Honda dealer. No more leaks. \
03-30-2009, 12:30 PM | #2 |
Nice. If all of us can do this once per maintenance item we will have a good tech resource for the novice or the mechanically inclined but forgetful kind.
We should sticky this as soon as you ad honda part# and engine modle...although 125 china horiz. engine says it all
'91 Yamaha Warrior- stage 2 '83 Honda ATC 70 '08 Yongjiang 125cc mx (Loncin) '08 Yongjiang 150cc atv (Jinlong) |
03-31-2009, 02:01 AM | #3 |
I edited the post to include the part number.
Cheers!
06-20-2010, 02:13 PM | #4 |
I'm sorry I missed this post when you first wrote it, W&G. As usual, your writeup is great, and the photographs are wonderful. If I ever get a Honda engine, I am certain I will spend a lot of time reviewing your excellent posts!
06-20-2010, 03:38 PM | #5 |
Thanks Spud.
06-20-2010, 08:28 PM | #6 |
Me too, thanks You should add it to the tech stickies.
"Be excellent to each other" "We are all human. Let's start to prove it!" |
07-18-2010, 12:28 AM | #7 |
PULLEY REMOVAL
Is that a tool for removing the pulley?? if so does it work on all the motors???
07-18-2010, 01:36 AM | #8 |
So far, it has worked on XR200R engines from the early eighties, a GY6 ATV and a 125 pit bike Honda clone.
02-21-2023, 02:22 PM | #9 | |
02-21-2023, 04:01 PM | #10 |
No, it doesn't, Thumper, it only drives the oil pump shaft, there is no counterbalancer. At the other end is the cam sprocket
