10-27-2010, 01:19 PM | #1 |
16 tooth front sprocket Qlink XF200/XP200 question
Is there sufficient chain length on a new 2009 Qlink XF200 to install the 16 tooth front sprocket?
Thanks |
10-27-2010, 01:22 PM | #2 |
As I recall I installed a 4 tooth smaller rear sprocket with the 16 tooth front sprocket and did not need to alter the chain.
I'd go that route if you want to gear your Q as high as practical. I got my parts from JP Motorsports in San Diego. I think you could add a tooth to the front and use the stock chain with no other changes, but I'm not sure.
Happy to serve. |
10-27-2010, 02:11 PM | #3 |
FastDoc,
Thanks. Rain is about over here so maybe I can get a ride in. Nasty weather came in last night. |
10-27-2010, 08:31 PM | #4 |
Bar, I installed a 16T in the front and 44T in the rear and had no trouble with the chain.
10-27-2010, 10:37 PM | #5 |
I believe that was my combination.
Happy to serve. |
10-27-2010, 11:43 PM | #6 | |
I'm just planning on doing the 16 now or waiting until the chain wears enough to fit. Thanks |
10-28-2010, 09:09 AM | #7 |
Me and 2 other guys with Konker KMS 200 ( Qlink XF200 ) all did ours the same week with the 16T front sprocket. There was enougth length in the stock chain. My bike was around 150miles on the odo. There was only a few hundred miles higher. They also changed out the main jet in the carb from 122.5 to 125 , pilot jet to 35 We notice the response improved.
2009 Konker KMS200,06 Lifan LF200 GY5 (SOLD). 08 Sachs Madass , Royal Enfield 500 Bullet , Royal Enfield Diesel, Chang Jiang CJ750, Honda GB500 , 2010 Buell XB12s CG |
10-30-2010, 04:04 PM | #8 |
Did the 16 tooth swap today and am not looking for a 6th gear anymore. Nice and might try the smaller rear after break in.
10-30-2010, 08:27 PM | #9 | |
Happy to serve. |
10-30-2010, 10:02 PM | #10 |
FastDoc,
Good point. |
