Old 03-20-2017, 10:04 PM   #1
jet321   jet321 is offline
RIP wheel bearing
Finally got the bike running right today and took it for a ride, the rear wheel was wobbling and I stopped thinking the rim was bent. The rear bearing basically disintegrated.
I saw SeerAtlas's thread and read another with Pete, and concluded that you just have to pop out the old one and order what the 4-digit number and 1RS/2RS designation said, then swap them. Is that right? I took mine out, after a little bit of torch work, and it reads 6302 2RS and on the bottom it says CXCL. What do you guys suggest? What else should I do besides put in the new bearing? Thanks.
2015 Hawk 250 ~ Aftermarket Exhaust/K&N/LED everything/16/44T/Shinko 705's
Old 03-20-2017, 11:03 PM   #2
Azhule   Azhule is offline
New bearings for me must be... "Made in Japan"... and I always pop the seals before installing them to make sure enough grease is packed in them from the factory... then I enjoy many years/miles of trouble free driving/riding
Old 03-21-2017, 12:11 AM   #3
humanbeing's Avatar
CXCL is 10000% rubbish. CXCL http://www.cxcl-bearing.com/aboutus/...tentId=10.html = Tech support by KOTO (some doggy paper co. http://www.searchtmr.com/details?trq...22f08&hl=en_US)
Product from http://www.cugroup.com/ is good enough for that job. 1 of the OKish chinese brand...
I prefer a Swedish brand that started w/ S http://www.skf.com/binary/92-179206/...ls_6270-EN.pdf
Old 03-21-2017, 01:33 AM   #4
pete   pete is offline
pete's Avatar
I always go for made in Germany "FAG bearings"..
I never put more grease in the bearing as I want it to last...
not have to much drag from the grease making to balls/rollers
skid around the races instead of rolling...
How meany tests & $ went into working out how much grease should be in a bearing..
09 XT660R ...
06 TTR250 ...
80 Montesa H6 125 Enduro...
Current resto projects..
81 Honda CT110...
80 Kawasaki KL250A1...
http://www.remotemoto.com/
E-mail... xtpete1@gmail.com
Old 03-21-2017, 02:57 AM   #5
hertz9753's Avatar
Everybody knows that Sweden in the drop shipping point for Santa Claus.
Old 03-21-2017, 08:26 AM   #6
chuck   chuck is offline
Bone dry bearings from the factory?
Old 03-21-2017, 09:08 AM   #7
You guys crack me up
I've seen all kinds of bearings... "FAG" and "SKF" bearings included... be delivered with barely any (read... almost NO) grease inside the thing... reason I pop the seals and check/clean/repack with the proper amount of grease... I also like to use a "Marine" grade grease on my motos...
But hey... "to each their own" right?
Old 03-21-2017, 09:12 AM   #8
Ariel Red Hunter's Avatar
I think CXCL is the maker. I would buy an American, Japanese, Swedish, or German replacement bearing. Bearing supply houses carry these in stock. Buying online it is difficult to be sure where the actual bearing is made. Chinese grease is not very good. Someday it will be, but not yet....ARH
Old 03-21-2017, 09:51 AM   #9
Jet, those seen lots of water? Deep streams or pressure washing?
Old 03-21-2017, 11:04 AM   #10
You know, I have no idea, in my ownership..no, but I did almost get stuck in what I thought was a dry lake bed, so mud..clay....water, but that was once. That's the only time she's really seen elements besides some trails and road riding... Now the last owner, that's a different story. He was from what I could tell, very negligent with her, considering all the things I've had to change and fix on the hawk.
Do you guys think I should replace the front wheel bearings too? I mean this little incident has me worried considering the bike only has about 4k miles. I would just hate to be taken out by a chinese bearing ha ha
SKF??
http://www.ebay.com/itm/SKF-6302-2RS...gAAOSwoudW9Jrj
Old 03-21-2017, 11:15 AM   #11
SKF??
I hadn't realized that you bought it used. It's been a while since I've read your thread. Since bearings are cheap and it has a "mystery history", I'd change both front and rear, just because.... Easy enough to do.
Old 03-21-2017, 11:49 AM   #12
I bought it second hand, I got a great deal on it despite issues it had. I paid only $750 for it and then put almost that much in upgrades into it. I'll probably do front and back then, I mean it looks like it will be only $30 to do.
So just SKF or FAG brand?
Old 03-21-2017, 11:58 AM   #13
Either would be fine. I've used others with no problems.
Old 03-21-2017, 12:05 PM   #14
I watched some videos on how to install them, do you guys recommend a press tool? I need to grease the outside/inside the bearing (not the ball bearings), but what about the spacer or axle?
Thanks for all the replys
Old 03-21-2017, 12:21 PM   #15
I usually just knock them out with a drift thru the hub. If you don't have a bearing installer tool, find a socket about the right size as the outer race and knock them in carefully and flat.
Grease the axle and other parts. It help keep water out and will make removal much easier next time.
