Old 05-01-2017, 02:22 PM   #1
Jrack   Jrack is offline
Should I get an oil cooler?
Vader 125
So, I was wondering if I could get anyone's thoughts on an oil cooler kit. I'm probably going to order the piranha kit below(if I need to). Should I get it, or wait to see how it runs with new jets installed? It's running lean, so I know it's running hot. Would the kit help with this?
Getting jets in the mail today, stock carb. I'll probably start low and work my way up. The jets range from 80-98. (Stock is 78)
Problem is, I'm a noob, learning as I go so any input would be greatly appreciated!
Thank you all in advance!!!
https://www.amazon.com/Piranha-Compl...oil+cooler+kit
Old 05-01-2017, 03:07 PM   #2
Merlin   Merlin is offline
If your going to be pushing red line for long periods you'll need it.
Bashan Blaze
Mods: Alloy Rim's, Muffler, Mukuni VM26 Carb, Foam Filter, Tachometer, Volt Meter,LED Headlight, LED Blinkers
Old 05-01-2017, 03:29 PM   #3
Bruce's   Bruce's is offline
If your engine is a typical Honda horizontal clone ,we typically install them on all the 110cc and up racebikes .Not really sure if that helps you or not as riding them on the road is different from a pit bike .
Old 05-01-2017, 04:44 PM   #4
Skin Mechanic   Skin Mechanic is offline
Skin Mechanic's Avatar
Ditto Merlin's comment. If your gonna be at WOT most of the time, it's a must. I installed a racing CDI and coil on my bike so I did an oil cooler before I took it for it's first ride. With the cooler my bike takes about 1 1/3 quarts of oil to reach the full mark on the dipstick, which I couldn't see until I spray painted the dipstick white.
And don't get reamed $$$ for an oil cooler that doesn't even use banjo fittings, when you can buy one from ebay that does use them, for 1/2 the price:
http://www.ebay.com/itm/252370884662...%3AMEBIDX%3AIT
2017 Ice Bear Little Monster, work in progress
2007 Aprilia RSV1000R, unreliable piece of sh*t
2007 Moto Guzzi Breva V1100, epitome of reliability
2000 Moto Guzzi California V11, resting in pieces
The cage: 1998 BMW Z3, 1.9L w/full Dinan engine upgrades
Old 05-01-2017, 05:01 PM   #5
Awesome, thanks I'll probably get it or one like it.
Old 05-05-2017, 10:14 AM   #6
prismways   prismways is offline
prismways's Avatar
Just ordered mine. thanks Skin!
Old 05-06-2017, 05:13 PM   #7
You're welcome. One thing to note, the mounting bracket included in the kit wouldn't work with my carb pointing forward. If your intake is taller you may be able to use it. I had to McGyver a bracket from a scrap aluminum "L" from another bike project. You can get aluminum bar and channel stock from Lowes.
Old 05-14-2017, 01:48 PM   #8
prismways's Avatar
Hey Skin,
can you post pics of how you connected the hoses on the sides of your engine?
Trying to figure out which bolts to remove.
thanks!
Old 05-14-2017, 03:43 PM   #9
Hey Skin,
thanks!
The upper hose loops back on itself and the lower hose runs under the head to the fitting on the left side. I ended up zip tying the lower hose to the left side of the oil cooler frame to keep clear of the exhaust.
Old 05-14-2017, 09:38 PM   #10
prismways's Avatar
ahh. interesting. so those bolt holes are made for an oil cooler? I'll check on mine. thanks
